The Varex sounds perfect for you. Sound ON for fun and sound OFF for cops/missus. Have your pie and eat it too. Wish I got the varex.... awesome setup.
haha thats what my mrs says. I like it loud, tells the person next to me to watch out, lol. Just love the echoing noise in tunnels and the constant hum, e.t.c...
Ive got the varex. The note isnt as good as the others but at the touch of a button you hear nothing full on stealth mode. I love it..
ROFLMAO :stupid:
Absolutely love the Fujitsobo naming systems....
"Power Getter" to... get.... power
"Legalis" for being street legal
"Wagolis" for... wagons....
Their marketing manager needs to be promoted. Absolute gold.
If you're after off the shelf jap kits, I'd suggest a Fujitsubo Legalis Titanium. Nice exhaust note, not too loud/annoying.
did u end up getting 1??
im thinking hard about getting one...its tempting..
Of course matey :stupid:
I was a guinea pig of sorts... being I was the only one with a EPA lol.
Benno stuck with me and my many many failed EPA's, and a decent setup was reached that can be quiet when required for "legal" purposes, and near enough to legal on the street that most people shouldn't be hassled. Was a LOT of hair tearing involved... but worth it at the end of the day.
Thats coming from the 120dB exhaust i had before. I'm now the quietest car on SAU cruises, but I know ill flow 400rwkw :D
Ye two issue with the Varex
1. The exhaust note is shit
2. Its still EPA defectable.
Its adjustable. Nothing controllable by the owner/operator is legal like that. What's to stop you driving off and flicking a button? Nothing... hence its illegal.
Any adjustable flange/plate in the exhaust is illegal.
Any plate must be FULLY welded in, and not spot welded - fully round edge.
I really don't see any difference...
Your mega $ exhaust is 'near enough' to legal...near enough is not legal. So when it comes down to it, IF you get EPA'd, you have to modify it to pass. Now that may be a simple addition of an extra resonator etc, but it's still effort.
Now, your exhaust is quieter than most in its regular form, but so is a Varex when closed. So what's the difference? There isn't one. Both exhausts (a $400 muffler and your $1500-2k exhaust system) need to be modified to pass IF they are pulled up for testing.
If you have a Varex and drive around on the street with it closed for the most part, then chances are you won't get EPA'd, just as you'd not expect to with your system. But at the end of the day if you did get done, both require simple modification to pass, only one is a shit load cheaper.
So at the EPA station they would check for butterfly valves specifically?
If so, varex should make a full cat back with the RC butterfly valve somewhere much more upstream, so it's not detectable if you look at it from the back.
Near enough is good enough when your chasing power, you'll never get a 650hp street car totally legal. There is always compromise.
I would imagine for a RB, i reckon probably the closest in Victoria to legal for my power range :stupid:
The Varex also has the control over bypass in the main exhaust, this is also going to cause as restriction even when open. Plus it they make the car sound shit in my opinion.
Once you drive around for a week with the Varex in "quiet" mode you'll soon be leaving it fully open once you see just how restricting and unresponsive the car becomes... its such a pig you wont want to drive the car its literally that bad. So in the end you'll get EPA'd anyhow.
So this then makes the Varex something of a mission to pass. It requires fitment of a totally new muffler.
I you do the ole 2.25" pea shooter that is then noted on the EPA sheet... where as im noted down as a 3.5" so im infront there as i cant be questioned if i get a on-road EPA station
I actually want to test mine without any changes
I suspect the 92dB tester has a poorly calibrated meter based on the fact it was 92dB and the next day it pulled 86dB @ the other place in exactly the same format... so i wouldnt be surprised if all along I was getting shafted by the fked tester/setup and then thinking my exhaust wasn't legal, when in actual fact it might well have been :D
Phatboy - the restrictor needs to be right at the end. Having it up the front doesn't make much difference.
We've tested a similar set up. Its all about the noise @ the outlet between the last muffler and the tip
I don't think you're any safer with a Varex as I wasn't pulled over, it was likely an off duty cop on his way home because if I had've been up it... I have no doubt in my mind i would have been pulled over. So that means I would have been reported on "cruise" which is WELL below the EPA requirements.
That's the law though, you can be reported on suspicion, not fact.
I know for a fact that cruising around my car is quieter than 90dB. Its not until it climbs above 4500rpm that it gets over... and if i was even @ 4500rpm in 3rd I'd be in licence loss zone.
So the EPA I received was largely bullshit as most of them are because if i was 4500rpm under load in 3rd, i would have had the red and blue in my rear vision mirror
Overall i still class my exhaust better than anything I've seen yet, and the Varex is a worse option - not a same level one.
i just had my test, it came in at 94db but i wasnt very happy with the way the test was carried out considering it was a busy road and on the other side of that road was a tyre shop making alot of noise, and i had to pay $38 for something that took this guy under 5 mins to do the whole test. he was a very rude guy.
i think its near impossible to have a fast car and have the sound under 90db with these engines, i think they test them up to high in the rev range, the amount of times im that high is very rare im usually in traffic and you can barely hear mine. i can come home at night and not wake up my mum which is saying something cause she is a light sleeper lol.
You can have a quick skyline under 90db, the exhaust Ash is talking about is a 3.5 inch which will output monster power which is amazing how quite they are, I have herd a few and I am considering getting one myself as a 3inch just won't do.
I had a Fujitsubo exhaust (two oval mufflers) on my manual stagea which had 265 rwkw and was as quiet as stock on part accel, sure it was a little restrictive but until I really opened it up you cound ont even hear it, my mechanic even thought it had stalled at the lights it is so quiet that he tried to turn it over again while it was still running!!
It didnt have that destinctive RB rumble but I loved how quiet yet how powerful the car was. I think it all depends on your ultimate goal, if you are happy with the 250ish rwkw then it is possible to have a very quiet and legal exhaust but if you are wanting huge power then you have to pay for it and go for a Racepace style exhaust.
How much are the full GTR Racepace exhausts roughly? or even a cat back?
LOL.....$10 buxs he gets an off the shelf one..then gets a defect then gets a muffler replacement (1 and a half inch outlet type so he can pass .
But seriously...a well built custom job is the way to go.
I have a large resinator...kakimoto...and a large custom side entry muffler(great for any gtr)..3 1/2 inch stainless and
am way under 88db...lol
The muffler was made to fit the entire available area....a bit of weight...but I have no head aches anymore.
Should post up a pic.....
:) pics please :(
Of course matey :)
Thats coming from the 120dB exhaust i had before. I'm now the quietest car on SAU cruises, but I know ill flow 400rwkw :(
i know i will end up getting 1 from benno but probably towards the end of the year ... his so good at taking my money haha .. i need a damn good holiday where i can get mashed and pass out everyday on a beach somewhere so thats going to take priority now :(
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
