Has anyone here removed the front and rear bumpers on the M35 models. I'm going to get the front and rear bumpers resprayed and want to make sure I don't break anything.
How about removing the interior rear door card? Need to get the body panel off under the rear lights to paint as well.
Also the side moulding on the doors, are they just taped on so there are no holes in the doors?
Thanks,
Rhys
Edited by StageaM35
https://www.sau.com.au/forums/topic/266263-m35-bumper-front-and-rear/
yeah the side moulds are just double-sided taped onto the car. be VERY careful when you remove them, maybe heat them up gently before removing them, or leave the car in the sun for an hour before you do it
as for the bumpers, im not sure, but id like to know too lol
ive done the front bar
lot's of little clips and 2 bolts from the fenders that hold the bar on the guard..
also the bottom splash guards are held on to the front bar as well
u need to remove around 20-30 bolts and plastic clips to take the bar off
Thanks guys.
Front bumper doesn't seem to be much of a problem.
Its the rear one that interests me the most, seems a lot of the clips etc are hidden from the eye not like the front one.
Also forgot to ask about removing the rear boot interior door card, will edit my post.
Cheers :thumbsup:
rear bumper is rairly streight forward, you need to remove the rear inner pannels to get access to some bolts /screws that bolt through the inside of the rear quarter pannels down to the rear bar (these ones are fun, dont drop the bolts as you will have trouble finding them). then there are a couple of screws at the back.
On the rear tailgate there is a plastic panel under the lights and number plate that I wish to remove. Has anyone seen how this comes off? Just asking first before I 'test' how it does :) .
I pulled off the insides of the tailgate today to fit a reverse camera and if my memory serves me right there are bolts on the inside of the tailgate that hold that piece on.
To get to them do it in the following order.
1) remove bolt just behind wiper motor. There is a black square cap covering the bolt.
2) pull the black cover on the tailgate (covering the wiper motor) up. there are 4 clips holding it down that just pull out, straight up.
3) remove all the little brown, and black clips holding on the carpet cover. On all 4 sides. It should just come off now.
Cheers
Andy
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
