good evening all,
its finally time to say goodbye to my cefiro.. i did have it up for sale a couple of time but ended up keeping it... either way i spent a fair amount of time, money, blood sweat and tears into this... so getting to the point here it is...
a31 cefiro with about 75xxx kms on the clock from memory but the engine has just under 65xxx kms on it
s15 sr20det
six speed manual (yes one of the only six speeders in an a31)
near new clutch
modified tailshaft to fit
s15 LSD
tien springs front and rsr shocks and springs rear... these sit the car nicely and has a very nice ride
s15 full front and rear 5 stud and brake upgrade
3'' exhaust leading to a 5.5" apexi cannon (very nice sound)
Trust type R bov on custom intercooler piping
gt-r intercooler
blitz metal air flter
jdm balla bearing t28 s15 turbo on stainless manifold
full r32 gt-r interior with seats front and back
nardi steering wheel
trust boost guage with trust guage holder
sentral 20 water temp guage
comes with 16x8 16x8.5 mesh wheels with decent tyres
will also throw in a set od s15 tyres
the car is kitted in uras bodykit
flared front and rear guards (done professionally)
sprayed in mazda rx8 velocity red with a nice old pearl over it
not regoed but just spent a fair whack of money at the mechanics cleaning her up for a blue slip..
i have no time to work on this car anymore as imma at uni full time and also holding a ful time job down so want a smooth quick sale... might have forgot a few more things so will update later as i remember
so for now will leave the price at $13,500 negotiable or will swap for another car with cash adjustment either way
post-24735-1240308155_thumb.jpgpost-24735-1240308176_thumb.jpgpost-24735-1240308192_thumb.jpg[att
achment=218596:6.jpg]
https://www.sau.com.au/forums/topic/266457-nissan-cefiro-s15-sr20t-six-speed/
  • 2 months later...
  • 3 months later...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
