Just came across this during a google search, thought somepeople may find it interesting :)
http://www.nissan-global.com/EN/NEWS/2001/.../011016-01.html
Gives information on the model and what is different with the ARX, i.e. ride height etc.
https://www.sau.com.au/forums/topic/266533-m35-press-release/
yes that would be right, its also possible the gearbox is 'programmed' to output a different signal
or it would get the speed from the ABS computer via its sensors which are already programmed with the rolling diametre of the relevant car.
Edited by zei20l
it's nothing really
just thinking of changing my cluster to a RX or RS model so i can run lower profile tyres when i lower the car
You could probably get the Nismo cluster in there. I believe that was designed with the RS/RX in mind.
Vaguely recall reading that it is calibrated for 18/7.5/45... ie the LMX5's
wait for the dollar to get better, IF it ever does
Yeah man, me too.
S l o w l y getting there.
Can have a Nismo suspension kit sent over for a bit less than $2k atm. No good for ARX though.
HKS Hipermax maybe Danny?
just like i said :blink:
would be good to find a written off ARX we could part up.... i know where andy lives!
Ok, I've been thinking about it, let's go borrow Andy's diff centre lol ;)
I'll have to keep my eye on the wrecker's incase one comes in, I might check if NissWreck will bring one in for me :) Their next container isn't due for a few months however :wub:
I'm sure between us all including the ARX owner's we could buy nearly the whole car up :)
i wouldnt mind the nismo, add some sway bars and it will handle nicely!
i dont think you want hypermax, get the HKS superwagon R+ (i think R+)
mmm, Nismo suspension with SK's sway bars... Anyone know where I can get some by any chance seeing as SK as gone walkabouts?
TIEN Super Wagon
HKS Hipermax LS+ (adjustable)
Ok, I've been thinking about it, let's go borrow Andy's diff centre lol :wub:
I'll have to keep my eye on the wrecker's incase one comes in, I might check if NissWreck will bring one in for me ;) Their next container isn't due for a few months however :blink:
that sounds like a good idea..
i wanna replace some stuff on my car..
ahhh apologies! i knew something was wrong in my head! thanks haha
Ahhhh if only that was the case, sorry to break it to you, there are lots of things wrong in your head :blink:
xoxoxo
dont make me whip your M35 with my Fiat again!!!
... and when your Fiat is tired, run down and defeated, I'll pop it in the back of the Stagea and drop you and the Fiat home :blink:
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
