  • Replies 140
Yo, Ive got a '95 R33 GTR here in sydney for wrecking as it unfortunately can't be complied
It's silver and has approx 44,000 ks, series 1. I can post almost everything from the car, or pickup is available. Will post some more pics in the next few days
R33 GTR rb26dett motor, complete engine with approx 44,000 ks. Compression test came up perfect- ~165-170psi each cylinder
Includes turbos, wiring loom, ECU, manifolds, injectors - $5000 ono
17x9" Axia? (jap wheels) +18 offset wheels with Dunlop Lemans LM702 tyres, front 2 have about 50% left, rears are pretty much on the tread markers
$1000 ono
5sp Manual GTR box, good nick.. includes slave cylinder, shifter - $1000
HKS 3" catback exhaust - $200
Exterior stuff
R33 GTR front bar - paint is cracked + grazed a bit on drivers side. includes blinkers - $400
R33 GTR grille - $250
R33 GTR front guards, includes GT badges and blinkers - $500 pair
S1 headlights - $400
R33 GTR front reo bar - $150
radiator support/ nose cut - $300
R33 GTR sideskirts + rear pods - $200
R33 GTR bootlid + spoiler. Paint is a bit faded on the pass side near windscreen, includes GTR badge - $400
Rear 'Skyline' garnish - $50
Guard liner plastics, both sides - $100
Brake vent plastics - $100 pair
Tail lights - $50 each
Side mirrors - $50 each
Passenger door minis door trim - $150
Drivers door minus door trim/switches - $200
post-35556-1240393680_thumb.jpg post-35556-1240393701_thumb.jpg post-35556-1240393200_thumb.jpg
post-35556-1240393715_thumb.jpg post-35556-1240393732_thumb.jpg post-35556-1240393766_thumb.jpg
Engine bay stuff
R33 GTR afms - $200/pair
R33 GTR airbox & snorkel - $150
Engine Mounts - $100/pair
GTR BM-57 brake master cylinder - $120
Stock dump pipes + front pipe - $150
Stock BOV pair - $120
Stock BOV recirc piping - $100
Stock FMIC piping - $100
Stock Calsonic FMIC, some damage to the bottom though it still holds pressure fine - $50
R33 GTR A/c condenser - $150
R33 GTR radiator- $100
Thermo fan - $80
GTR Washer bottle - $30
fuse box lid - $20
radiator overflow bottle - $20
Charcoal canister - $30
Bonnet lining - $50
post-35556-1240393555_thumb.jpg post-35556-1240393670_thumb.jpg post-35556-1240393834_thumb.jpg
Suspension/brakes/driveline
Front & rear Brembo calipers + pads - $1750 full set ONO
Stock suspension, full set - $250
GTR front + rear swaybars - $150
GTR rear diff - $500
standard swaybars - $80 each
Front upper control arms - $50 each
Rear lower control arms - $50 each
Rear 5 stud hubs - $160 pair
Handbrake assembly & cables - $160 pair
17" space saver tyre - $50
Interior stuff:
R33 GTR front + rear seats + door trim, complete set - $1600 ono, will probably seperate
GTR instrument cluster, carbon fibre look cover ~44,000ks - $250
GTR 3 gauge centre DIN cluster, nismo white face cluster & carbon fibre look cover - torque, oil temp and boost - $175
post-35556-1240393321_thumb.jpg post-35556-1240393332_thumb.jpg post-35556-1240393294_thumb.jpg
Steering wheel with S1 airbag (some wear on the wheel but airbag is great) - $150
Complete Boot interior - $100
Drivers door window switch (suit s1/s1.5 R33) - $80
Drivers window switch surround (s1), bit worn - $30
Drivers door window motor - $80
Passenger door window motor - $50
Large dash surround plastic with clock etc (s1) - $70
Gear stick surround (s1) - $50
Ashtray - $25
Glovebox - $40
climate control - $40
Seatbelts, full set - $80 (will seperate)
If you're after any random bits and pieces that arent listed, shoot me a PM- got the whole car available
Cheers!
Hi which part of sydney are you at?
hey what is the HKS Exhaust ? is it the whole thing from the cat back and what is it made out of ?? PM ASAP
Yep, whole thing from the catback, PM sent
how much for the rear parcel shelf?
Sorry mate parcel shelf is sold
hey mate u still got the brakes???
brakes are sold pending payment at the moment
Front bar and lights still for sale?
Yep front bar and lights still for sale. Pm me if interested
How much for the rear seat?
$200 for the rear seat (both pieces)
hey mate
do you still have the front diffuser?? if its a silver 95 model it should b black and either plastic or fibreglass.
if you still hav it, what sort of condition is it in and if its in good nick how much would you want for it??
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
