Hi,
I've currently got an '95 r33 GTR with two HKS Pod Filters as you can see here http://home.austarnet.com.au/myra/gtr_filters.jpg . But as you can see its a litte tight with the custom aluminium radiator and HKS intercooler piping - but stock cooler. Basically I was looking at some form of shielding & maybe some sort of cold air induction setup. So I was looking at the UAS R33 GTR Air Box. Products are from http://www.uniqueautosports.com.au/priceli...TR%20engine.htm and here http://www.uniqueautosports.com.au/priceli...t%20Filters.htm .
As far as cold air induction goes I wouldnt mind some sort of snorkel :- eg R32 GTR Cold Air Induction Snorkel (fibreglass) but the only one UAS list is for the r32 (how much modification would this require? Wouldn't mind it if it saved me some trouble with making my own even with a little modification.
For cooling I guess you run to the bottom indicator intake.
http://www.uniqueautosports.com.au/pricelists/price%20list%20GTR%20engine.htm :P/http://www.uniqueautosports.com.au/...R%20engine.htm ;)/http://www.uniqueautosports.com.au/...R%20engine.htm
So at the moment I'm looking at the carbon fibre UAS R33 GTR Air Box.
Any feedback would be great.
Cheers,
Geoff
P.S. The filter foam in the pods is degrading so I was gonna replace it - looks like they are both 150mm => see pic. Can I replace these with the 200m foamies ??? it would be really tight.
http://home.austarnet.com.au/myra/filter_size.jpg .
P.P.S I was also buying a HKS exhaust cam gear - should i buy the intake one to go with it? to make the set?
https://www.sau.com.au/forums/topic/26677-cai-questions/
Dont know a thing about the UAS stuff, personally I find it a bit expesive.
CAI, why not do the usual and get some 4" pipe and make a feed that comes in underneath the pods?
Then just either a partition or a box. If you are willing to spend the sort of mony UAS are asking, why not get a custom box made - or have a go your self?
As for filters, I would imagine that it would be easier to buy the 150mm replacements, otherwise you may find yourself cutting down the 200's, which also would not be difficult to do. Just trace around the old filter and get into it with the scissors:) It is a good idea to replace them regularly though, as believe it or not, I have seen damage to the compressor wheels of turbos that was attributed to the filter foam degrading and going through the compressor - which means it also sent through the cooler and into the engine.
https://www.sau.com.au/forums/topic/26677-cai-questions/#findComment-566301
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
