RB25DET long motor - rebuilt with tomei cams $1800
GTR copy front bar - this is a jap FRP bar and fits great, very sturdy although has a few cracks where i hit it. $200
Centre console - good condition $60
Alternator - $80
Turbosmart BOV - $100
Ignitor module - $30
Rear Taillights - $150 for both
Headlights - $300 for both (series 1)
Bonnet (black) - $100
Diff - $150
Cat back exhaust - $200
R33 GTR grill (original) - $100
Clear skyline panel between taillights - $50
Nismo carbon pillars - $30 (comes attached to pillar)
https://www.sau.com.au/forums/topic/267261-r33-wrecking/
PM's replied
Alex: You get the long motor, does not have injectors, exhaust manifold, turbo, plenum. So basically head and bottom end together running. Has been off the road for a few months now but was running perfectly when i removed it, have a few vids etc..
https://www.sau.com.au/forums/topic/267261-r33-wrecking/#findComment-4559777
Alternator - $80
Diff - $150
https://www.sau.com.au/forums/topic/267261-r33-wrecking/#findComment-4560831
Alternator - $80
Diff - $150
Eii im intersted in the exhaust,
is it stock or did u buy it? +
is it the whole thing and will it fit an r33 s2?
https://www.sau.com.au/forums/topic/267261-r33-wrecking/#findComment-4560839
PM's replied
Nismo carbon pillars have been sold..
R33gtstseries - the exhaust is an aftermarket item. It is steel with a stainless cannon. I bought the car with it years ago. It is 3.5 inch and comes is from the cat back all through to the end. The cat was changed to a high flow item around 15,000kms ago. Comes with mounting brackets etc.. I dont see why it would not fit a series 2, basically the same car. Send me a Pm if you want to swing by and look at it.
Basti - The grill needs modifying to fit, it sits perfectly between the headlights although you will need to play around with brackets to make it fit. Its not very hard but looks much better than a standard item or replica grill. It has some paint damage to it so could do with a re-spray. PM me if you want pics and ill get some for you.
https://www.sau.com.au/forums/topic/267261-r33-wrecking/#findComment-4561831
yeah i'd like pics man. i dont mind paint damage cos the front of my car needs respray anyway. whereabouts in melb are you? can i pick up?
edit: oops. you said pm and you are in syd. ok how much for postage?
https://www.sau.com.au/forums/topic/267261-r33-wrecking/#findComment-4571833
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
