Hi all,
Can anyone assist with a continuing problem I am encountering with massive judder and squeel seemingly from the front left of my car. After a warm up lap it starts at turn 6 and gets progressively worse whereupon it's useless to persist. I can put up with the squeeling, but the judder is not good.
My brake set up is AP Racing with Ferodo Racing pads (2 very shortened track days old). I am about to take it in to be looked at (again) by my mechanic who suggest changing to a new pad compound (hawks). I never had this problem prior to changing the pads ( don't know what the prior pads were)
Thanks in advance.
https://www.sau.com.au/forums/topic/267270-judder-and-squeel-at-sandown/
The shuddering can be tyres, can be pad deposits on the rotors, can be warped rotors, From memory you are running the old GT Spec 6 pot APs, i would personally guess its pad deposits if its not there at high speeds when cold.
Hey Roy,
I am running 4 spot AP's. After the first incident at Sandown I took the car back to the mechanic thinking the pads were scrubbing on the alloy hat when hot, but i was told there was plenty of clearance, even though the aluminium hat is scored. I did a track day at Phillip Is after this without incident then Sandown and the same happens.
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
