Do a full exhaust first. The car will make more boost pressure by itself as it is taking away a restriction.
Upping the boost on a standard car won't give many gains as there are still large restrictions.
wondering if anyone can help me i have a hks ev00388 boost controller ive recently changed to bigger front mount but 1 vacume hose that use to go to the original intercooler piping dosnt have anywere to go can someone help ive tryed numerous ways but it just keeps boosting untill it hits boost cut and throws me around, i have 1 vac hose going to the turbo 1 going to the plenumand one that dosnt go anywere ?????? any help would be appreciated
The vac line that doesn't connect to anything, Is that the line that the other end connects to the boost controller? Because if the controller has no idea what boost the car is running it wont be able to regulate it.
yes it goes to the little box that sits in engine bay has 1 line to turbo 1 to plenum and 1 going nowere can u tell me were it goes cos now it has after market intercooler piping were it used to go isnt there anymore
So you have 3 vac lines coming out of the little black box?
That hose needs to go back into intercooler piping. As stated it controls boost.
you can get an air nipple welded or a screw in type from like repco of sorts.
Im sure this has been discussed many types, search intercooler, nipple.
jacked thread here... soz :P
But there is already 1 vac line going to the plenum that should be all the controller needs to tell what boost pressure the car is running. Why would you need 2?
just rip all that crap out and connect one side of the boost controller to the wastegate on the turbo and go to autobahn or repco and grab a little brass bard fitting and screw it in the cross over pipe( will have to drill and tap it first) then plug the other sside of the boost controller onto your bard fitting and hey presto your done. go for a drive and set it at around 10- 11 psi on a stock setup. anymore and well we all know what happens. lol
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
