Hi
Any-one have any info on mod parts for the NM35. I am trying to find coilovers, intercooler kit, pod set-up, ecu, exhaust etc.
Have you had a look through the M35 Info topic to see if some of these are covered there?
Most of these things have been discussed at some point over the past few months, do a search of the topics and you may find most of the answers.
Hi
Hi Nick,
Welcome to the forum.
What kind of info are you after?
Company names? Product names? Product numbers?
Nothing special about the NM35 in regards to mods.
Just your usual suspects such as ARC, HKS, Bilstein, Nismo, Blitz etc.
Don't bother looking in Aus unless you are after filters, wheels or brakes.
Almost everything else will have to come from Japan of the US.
Hi Nick,
Hi Nick,
Thanks for the help, just picked up my MN35 in Sydney, fresh of the boat. Drove it back to Brisbane, great wagon, can't wait to spend some money on it.
The first thing I am doing is the wheels and coil-overs. I have all the info on who makes them, but am trying to find a decent price.
If any-one has any connections or advice on where to get a the best price on Tein or HKS it would be greatly appreciated.
Could any-one also tell me how to get the auto gear knob of so I can remove the console. Also need to get the dash cover/trim of to remove the CD Player. I have had a look and it is not obvious and I don't want to damage anything.
Thanks
Thanks
Coilovers would be cheaper to get shipped over than to try to get a Tein or HKS Australian supplier to get them in.
Ain't going to be a cheap exercise.
Yep, as stated the gear knob is basic stuff. Just pull the grey plastic base down (you won't break it), pop the u shaped clip out and pull the main part of the knob up (Iain & Stephen - No need to comment).
HERE is how to remove the rest of the console to get behind the cd player
Edited by iamhe77
Oh sheesh! you just like to spoil all our fun. :cool:
knobs and flanges......
dude youre just leaving it open for me :P
Hmmmm... Knobs and openings, someone is frustrated :happy:
Don't know you that well mate!
But I suppose if that is what floats your boat, than fantasize all you want!
I would be keeping Iain well and truly away from your dump pipe if I was you man :D
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
