Hi
Any-one have any info on mod parts for the NM35. I am trying to find coilovers, intercooler kit, pod set-up, ecu, exhaust etc.
Have you had a look through the M35 Info topic to see if some of these are covered there?
Most of these things have been discussed at some point over the past few months, do a search of the topics and you may find most of the answers.
Hi
Hi Nick,
Welcome to the forum.
What kind of info are you after?
Company names? Product names? Product numbers?
Nothing special about the NM35 in regards to mods.
Just your usual suspects such as ARC, HKS, Bilstein, Nismo, Blitz etc.
Don't bother looking in Aus unless you are after filters, wheels or brakes.
Almost everything else will have to come from Japan of the US.
Hi Nick,
Hi Nick,
Thanks for the help, just picked up my MN35 in Sydney, fresh of the boat. Drove it back to Brisbane, great wagon, can't wait to spend some money on it.
The first thing I am doing is the wheels and coil-overs. I have all the info on who makes them, but am trying to find a decent price.
If any-one has any connections or advice on where to get a the best price on Tein or HKS it would be greatly appreciated.
Could any-one also tell me how to get the auto gear knob of so I can remove the console. Also need to get the dash cover/trim of to remove the CD Player. I have had a look and it is not obvious and I don't want to damage anything.
Thanks
Thanks
Coilovers would be cheaper to get shipped over than to try to get a Tein or HKS Australian supplier to get them in.
Ain't going to be a cheap exercise.
Yep, as stated the gear knob is basic stuff. Just pull the grey plastic base down (you won't break it), pop the u shaped clip out and pull the main part of the knob up (Iain & Stephen - No need to comment).
HERE is how to remove the rest of the console to get behind the cd player
Edited by iamhe77
Oh sheesh! you just like to spoil all our fun. :cool:
knobs and flanges......
dude youre just leaving it open for me :P
Hmmmm... Knobs and openings, someone is frustrated :happy:
Don't know you that well mate!
But I suppose if that is what floats your boat, than fantasize all you want!
I would be keeping Iain well and truly away from your dump pipe if I was you man :D
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
