Hey everyone, I own a VL with an RB25DET conversion. I had it shipped over from TAS a bit over 3 months ago, and I'm still struggling to get it rego'd! Took it to the pits, did everything they said, blah blah blah, and then I had to send off a form to get approval for my mods (very light - FMIC, 3" exhaust), and of course, the engine swap. Waited about a month and just heard back from them yesterday, they told me that they wanted me to get it Engineered, and here's the killer; emissions tested!
So yesterday, I took it to one of the engineers on the list that they supplied, and he was a great guy, and helped me, pretty much passed right there and then. Now all that's left is the emissions test. I've been told only two places do it that can be ADR approved, Kostecki ($450 base, and $130 every hour it takes), and Orbital Engineering (not confirmed prices as of yet). So I don't want to go there, find out I fail, then have to pay the $600 odd it takes to get a re-test. I've heard you can get emissions tests from normal workshops etc etc., for around $60.
So I was wondering, can anyone shed some advice on whether you think it's worth going for it straight away, or hunting around to find somewhere to pre-test? If that's the case, can anyone tell me somewhere that does the tests? HyperDrive unfortunately don't, and that's where I usually go.
My current setup is:
RB25DET
3" Exhaust (with what looks like the stock CAT)
FMIC
Pod
Can anyone tell me whether they think it's worth having a shot first go, because it doesn't seem like those minimal amount of mods would do much to bring it over the limit..
The things that the ADR test for are as follows:
- Carbon Monoxide
- Hyrdo Carbon
- Oxygen
- Carbon Dioxide
- Oxides of Nitrogen (Not to be confused with Nitrogen Oxide)
So after that essay, what I need to know is; Do you think it will pass as is? Or should I get somewhere to check it before-hand? And if that's the case, where can I get it checked?
Thanks for your time, really appreciate any help I can get.
Cheers, Joel :thumbsup:
https://www.sau.com.au/forums/topic/267606-emissions-bro/
http://www.dpi.wa.gov.au/mediafiles/lic_ib...ht_vehicles.pdf
It's only just become enforced now. When I got mine done the IM240 test wasn't available to the public at the time, so I was able to submit my test done with a scangas, but I heard they would stop accepting those once it was available.... Looks like you will have to do that test, which sucks as only Kostecki will be able to do it, as unless they have changed Orbital only do it on a commercial basis for fleet cars etc, it's not/wasn't available to the public.
The test itself doesn't take long so the $130hr I'd assume would be labour charge in setting it up, getting the car ready etc, so ask them directly just what is involved with that.
But however your best bet would be to get scangas style checks done to see how they are coming up, as it will be a lot cheaper if you need to do more do reduce emissions, compliance workshops should be able to help you out with that.
Good luck anyway!
https://www.sau.com.au/forums/topic/267606-emissions-bro/#findComment-4563313
Good luck anyway!
Thanks mate, any idea which workshops in particular could do this for me? That's why I'm so stuck, haha.
Joel
https://www.sau.com.au/forums/topic/267606-emissions-bro/#findComment-4563364
http://www.skylinesaustralia.com/forums/Co...hr-t191756.html
Pick one of the mechanical based workshops from there closer to where you live & give them a call to see if they do that sort of thing, but I heard you can get them from places like automasters too so maybe give them a call too
https://www.sau.com.au/forums/topic/267606-emissions-bro/#findComment-4563380
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
