im planning on cleaning up my engine bay and want to redo the plenum as previous owner painted in gold :thumbsup:
can someone provided a step by step instruction in how to remove it please? just need the top bit removed that the TB bolts onto not the whole thing from the block.
ta
Ash
https://www.sau.com.au/forums/topic/267611-gttgtst-plenum-removal/
