Fs: 2.5" Diffback Custom Exhaust W/ Hks Super Drager Muffler
Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction. My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point... *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well. They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
