Just wondering if Lukey exhaust systems and their panel filters are worth getting for my GTS-T?
Could they make me a full exhaust system? I'm talking about replacing everything!
I prefer to source quality Australian made products than paying the extra premium for Japanese aftermarket parts. I believe we can make good parts too.
Let me know what you think before I lay down my coin.
Cheers.
https://www.sau.com.au/forums/topic/268441-lukey-products/
Lukey make friggin mad exhausts.
I had one on my Datsun 280ZX and if F**King growled hard.
A rumble on idle and a roar on full throttle.
Yes I believe it was custom made 2.25" full straight though with an aftermarket exhaust manifold as well.
https://www.sau.com.au/forums/topic/268441-lukey-products/#findComment-4574470
Sweet. I knew they were good but I didn't know how they would go on a Skyline. I'll definetly give it a bash.
Same with the panel filter. If no one has heard of or used them then I will try and be different. Could go either way but worth a shot. I should have one in by the end of the day.
Now last but not least... Just who would be good to get the exhaust fitted from? I need someone who knows Lukey and GTS-T's that only does quality work.
https://www.sau.com.au/forums/topic/268441-lukey-products/#findComment-4574879
I would just stick to the Japanese brands.
They don't cost that much anyway.
https://www.sau.com.au/forums/topic/268441-lukey-products/#findComment-4574905
Well I have been using the Lukey panel filter for almost a week now. And I can definitely say it was worth the buy. Much better power in the higher revs and a noticeable sucking/popping sound around 5,000rpm. And there is no increase in induction noise in the lower revs so you can still hear the turbo whistle.
Anyway I will still be going for a pod filter set up later on. I will all so be going for a JJR turbo back exhaust too.
https://www.sau.com.au/forums/topic/268441-lukey-products/#findComment-4583917
Ah ok...
I thought you were still deciding on which brand of panel filter you want to get...
If Lukey does the job then its sweet!
https://www.sau.com.au/forums/topic/268441-lukey-products/#findComment-4584146
So many jap part shops have stacks and stacks of jap catbacks, I wonder what it stopping you from getting one?
I want a turbo back exhaust from the one company. If I did that from the likes of lets say HKS... Then I would be broke.
And sorry I should have been more specific.
Edited by daslingdale
https://www.sau.com.au/forums/topic/268441-lukey-products/#findComment-4584356
sounds like those filters do the job.
i saw your from sunbury, same hear, hope to see you round some time.
https://www.sau.com.au/forums/topic/268441-lukey-products/#findComment-4584439
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
