Nissan Skyline R33 Series 2, Melbourne
Handling/Performance
TIEN superstreet coilovers (less than 2000k’s)
Whiteline front and rear sway bars
Front Strut brace (off a Stagea)
TOMEI short shifter
HYBRID Front mount
Custom Turbo-back exhaust
Hi flow Cat
Twin 4” muffler
HKS EVC (electronic dual stage boost controller)
RDA slotted Front rotors
Ferodo DS2500 pads all round
Apexi Power FC w/ HC
Exterior
Full respray in Cubanite silver (Mercedes Champaign)
Custom evo vent moulded into bonnet (actually serves a prupose, cold air straight to the pod)
Pod is contained in an aluminium box
Full explosive body kit
Nismo clear side indicators
20” Pegasus rims with Nankang tyres
Interior
GTR front seats
Seats and parcel shelf re-trimmed in black
Custom Dash surround (black with gold pearl)
Blitz boost gauge
HKS turbo timer
Sound
Alpine head unit (one of the new ones)
Focal Splits at the front
JL audio 4channel running speakers
2 x 12” Kicker comp subs
Kicker mono-block running the subs
Made 199.5rwkw with the Power FC at RE customs Dyno
All tuning done at RE Customs
Serviced every 5000kms or less with Motul Turbolite
$19 500 NEGOTIABLE
Price is negotiable, can also remove a few things such as computer, system or rims.
Owned this car since 2003. First owner in Australia, imported myself.
Bought it stock standard and have built it up over the past 5+ years
Reason for sale: I never thought I'd sell this, but it's just time to move onto something else
Contact:
PM or sms: 0433 117 369
pics coming in a few minutes...
Edited by LiQuid IcE
https://www.sau.com.au/forums/topic/268524-for-sale-gold-r33-s2-1997/
Dyam... That truly has to be one of the finest 33's I've seen in awhile.
Thing has got sex appeal HARDDD!
I think this is one of the few R33's going around Melb that actually stands out form the crowed without looking too "riced" up.
Good luck with the sale man. :P
  • 3 weeks later...
