  • Replies 69
Posted Images
This weekend people :)
Laurens making fruit tingle jelly shots haha
damnation, i was looking forward to this...
I have to go to a memorial service for a friend that weekend, and its in the hills so I can't make it ;( sorry for the late notice
raise em, sink em, and raise em again
-D
Can u please PM me Lauren's address Kye? I won't be staying all night, as I have a poker event at a mate's place to attend (and win some $$$), but will put in an appaerance.
Cheers
Oh no wonder why I couldnt find the address... the street name is two words, P**k V**w Drive, I tried to find the address via google map wrote it as one word,P**kv**w Drive ,(the way Kye wrote it in the SMS) lol
cheers for the good time :)
scorpion eatings was gold :dry: she swallows i seen proof
apoligies for thrashing out ya b ball court but the turnaround jump shot was on fire :domokun: people may have been blinded from overexposure to awesomeness
Edited by Inline 6
glad every one had a good time :P
the scorpion is still wriggling in my throat i swear...
and in the words of PK 'All good Girls Swallow'......
2 bottles of tequila, a bottle of gin, a bottle of sambuca and 4 cartons of beer went on sat night and atleast a carton of RTDs hahaha
oh and PK i have your jacket still
Cheers again to all who came
Lauren
xx
Cheers for a good night Lauren, sorry I had to leave early! Had work the sunday and was bound to be a busy day.
Had fun, was good to catch up with everyone that went. Heard some stuff went down after i left, Hope u didnt egg the emo's on scandy :D
I'm an emo kid, just as emo as can be!
-D
Had fun, was good to catch up with everyone that went. Heard some stuff went down after i left, Hope u didnt egg the emo's on scandy :(
so... hypothetically... if i bottled them... thatd be acceptable?
:D
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
