Ok have the powerglide out of the race car built for a 1000hp by Mike from MV Automatics,
its a full house gear box:,
-Manualised
-Shift Kitted
-Pro Tree Transbrake
-High Tuff Input Shaft
-7 Clutch High Clutch
-Chrome Molly Clutch Hub
-Deep alloy sump (TCI from memory)
Its Mikes high horse power package has everything except big planetary gears.
Done less than 10 passes
Will fit anything with a bellhousing adapter and stally to suit
Will throw in BnM Pro Bandit Shifter
Asking 3500 ono
Vortech Supercharger, Its V2 (helical cut gears) T Trim (impellar size) Blower, The one off the race car done approx 20 Race meets, Excellent Condition,
Have brackets, custom timing covers and plumbing to suit a VH45 if interested.
Asking 2900 ono
Complete VH45DE
ARP Head studs,
Copper head gaskets
Grout filled block
Ported and Polished heads
Double Valve Springs
Under 5 Passes since complete rebuild
Spare Crank
Spare Rods (Compete Set)
Spare Piston (complete set)
Spare Manifold
Spare Rocker covers
Spare Heads (not sure where they are though)
I understand the block is grout filled and good for not much except drag racing but it would be good for spares or to mimic the setup.
1000 bucks for the lot.
8 x 1600cc injectors 600ono
2 x Autometer Pro Comp Cylinder Head Temp Guages 150 ono
MSD DIS 4 HO - Distributorless ignition system 4 channel high output
Would suit a skyline on waste spark setup with 2 tach adapters (required for it to work with some cars ill throw them in)
600ono
4 MSD GM dual output Blaster coils with adapter bases for universal setups 250ono
With the ignition setup you can just about arc weld with it.
VH45DE Custom Hybrid Microtech LTX8-LTX10 Combo with extra outputs and onboard igniters 600 ono
Pair of FD RX7 Ekei Space savers used as front runners, they fit with a spacer plate and are fitted with cross ply tyres 250ono
Pair of 15 x 8 Drag way indies, nissan/ford pattern, fitted with 28 x 9 1/2" hoosier slicks from memory, these will not fit a 33 without serious modification and NA brakes 500ono
All still on the car, some of the gear is on ebay also, willing to sell engine components seperately, will swap the cross member for a standard 33 one or just sell it if someone wants it.
Will swap stuff for standard 33 bits, i need a driveshaft, manual box, clutch, manual brake pedal, clutch master cylinder, engine wiring loom, aftermarket intake manifold, 33 bonnet preferably fiberglass or CF, set of 17 or 18" wheels.
Will also sell the whole package if someone is interested, so with another block you can just bolt the whole lot into your 33 and have pretty unique street car.
Everything is still on the car atm, so it can be seen running, until some of the parts sell.
The car is sitting at the workshop in sumner park, which is where ill start stripping it.
Happy to answer any questions John - 0417 608 538
Got some piccies and more details on the blower, brackets and pipework? I'm putting a '45 into a 300ZX slicktop, the blower might go nicely...
Any cams in that built motor to go with the ported heads? If so I'm interested in that too.
  • 3 weeks later...
hey mate, just wondering what the autometer head temp gauges do exactly and what part of the the head do they monitor?
cheers mate
very good prices on everything, shoul't take long to sell.
  • 4 weeks later...
  • 4 months later...
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
