Hey guys, i'm about to buy the oil lines, i wanna have some more informations before if i can find them! I know it's a lot of question but i've though to put this in FAQ in eerything is settled. :D
Oil feed line
12mm x 1,25 in to -4AN adapter (block side)
The line -4AN What lenght do i need???
t3-t4 oil inlet flange -4AN with gasket and bolts
Do i need an oil restrictor? if so, wich size?
I just noticed that i have thread in the oil feed side on my turbo, can i still use something like that? http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewIt...em=350197014087
The guys who sold me the turbo told me that this thread was 5/16 npt, so i guess i can put a fitting directly in there???
Oil drain line
Adapter to rb25 block Wich thread i use on oil pan?
-8AN line
t3-t4 oil drain flange -8AN with 8AN adapter (flange to line), gasket and bolts
Water line
Any idea?
Thx!!!
