hey all after upgrading my kit and changing to a dump+front pipe im selling the following S1 parts
3" Front pipe to suit stock dump pipe, no gaskets included. i think its stainless steel but the heat has changed it toa light brown, also has a light graze underneath.
$100
Mspec front bar, stock white, mint condition, does not come with indicator wire connection clip, but comes with wireing, a connection clip will need to be sourced, should be easy enough from another nissan.
$200
Mspec? sideskirts, stock white, condition is a bit rough on the edge along the doors, a respray might be needed for the fussy.
$100
Stock rear bar, stock white, good condition apart from a small paint crack that i touched up seen in the pics, a respray will be needed for the fussy.
$100
Aftermarket GTR grill, not painted, never fitted.
$50
Parts are for pickup only, im in SE suberbs melbourne.
https://www.sau.com.au/forums/topic/269296-fs-r33-mspec-bodykit-front-pipe/
$100
$200
$100
$100
$50
Is there any chance you could send the grill to mackay, I know you said pick up only though i thought i would try
  • 4 weeks later...
items are still for sale
ADDED
o2 sensor origional
i thought my o2 sensor was buggered but when i replaced it nothing changed, so im assuming the origional o2 sensor is still fine and for sale - $30 pickup
ADDED
2 inch split dump pipe, bought from JJR, i have hand filed out the split pipe hole properly as they come a bit smaller, only seen 100km as upgraded to 3 inch bellmouth
$100
    • That's not a transistor --- it's marked ZD1 which makes it a zener diode. As to what the breakdown voltage is, not enough there to divine.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
