ive started clearing out my shed of all my r33 gtr parts i dont need any more for sale are will post up more parts and pics as i find them please dont hesitate to ask me questions via email [email protected] or after 6pm on (02)47391458
location is blaxland nsw will post australia wide at buyers expense
are twin trust t517z with 10 cm housings one turbo has about 5000kms on it and the other turbo has a brand new center never used
$2200ono
two 3 inch k and n air filters $50 each
3.5 inch stainless cat $200 ono
two garrett internal waste gated turbo bags $100 each
also for sale are a pair of r33 gtr front seats in good condition $800 ono
polished timing belt cover $100 ono
polished twin turbo cross over pipe $150ono
a r33 gtr vspec attessa pro ecu $300 ono
r33 gtr front upper control arms $100ono
ported standard turbo manifold for r33 gtr $150ono
standard r33 gtr sway bars $100ono
standard gtr air folw meters $100ono
gtr abs motor $100ono
r33 gtr hicas motor $100ono
rear wiper motor $20ono
r 33 gtr steering wheel with air bag $100ono
r33 gtr passengers air bag $100ono
r33 gtr rear seats $150 ono
thanks tim
Edited by timsr33
https://www.sau.com.au/forums/topic/269315-r33-gtr-parts-clearance/
Hi,
do you still have the abs pump for sale?
if yes, how much?
also stupid question but the r33abs pump should be a straight swap for the r32 gtr one right? mine is leaking atm
the abs pump is still for sale not 100%sure if it is a straight swap from what ive herd it is sorry i couldnt help more
Hi, What condition are the airflow meters in, Have they been tested. I'm interested in a pair of good ones.
Regards
Clynton
they were on my car no more then six months ago and have been in plastic bags since only selling because i got a haltech now and there not needed
thanks tim
$2200ono
now for sale also
5 splitt fire coils $200 good for spares
standard castor bars $50ono
standard bovs $50
unique autos oil air seperator $100ono
standard harmonic balancer $50ono
standard radio antenna $50 ono
hpc coated custom made top mount manifolds and 3 inch dumps $500 ono
2.5 inch divided dumps $100
standard water pump $50 ono
standard front and rear speaker $50ono
thanks tim
