The deal is .............. lol lol
Nandos @ Carseldine around 7.15 - 7.30 ish. If there are no parks in the top carpark where the shops are there is underneath but its a bit quiet down there. Im going in to have dinner so come and grab a bite or a chair, or stand in the carpark if you wish and ill come over. :)
Not sure if we are going to baskins @ aspley after that i guess it depends on who comes and what they want to do ....
Im pretty sure michael (GABNR) was being silly when he said then over to sunnybank. I wont be going any further than aspley tonight, but obviously you can all go wherever your heart fancies after that!
Hope to see some people there, if not then im having nandos and going home!
Donna ;) (PHT34)
Haha, yeah i was. Sorry Jaxt. Sif organise a dinner in sunnybank for the northsiders.
  • Replies 290
There were 5 cars there at various times. The woolies carpark was not our brightest idea as it was pcked! Who wants bloody groceries on a friday! lol lol
Next time we will make it just at baskins aspley, bigger carpark where we can park together, good night for a first try, hope to get more next time.
Maybe thinking next week again or maybe another day if people have ideas and are goin to come.
:D
yeh the carpark was chockers at that time, but we can only try, and it will get better, i didnt mind downstairs tho it was dead down there which is good for a few reasons, - plenty of parks and no problems from the po po..
either way was good to meet a couple of people.. cyas next time.
Pfffttt. Shy.
Sure sure :D
lol. I arrived fashionably late. Luckily I had my wingman with me because I was almost too scared to get outta the car. But then once we started chatting it was all good. Bit awkward when ur orange too...
Wingman ? hmmm do go on ;)
Orange ? Did you go dressed as a skittle ? :D
Lol my besty Ryan came with me. and no I wasnt dressed as a sittle lol. Got a tan for a photoshoot today so was all stinky and bright from my tan lol
LOL yes. Well I can smell it on me... then I get paranoid that im stinking everyone out with my tan smell
Cool, I learnt something today. Spray tan stinks. I seriously didn't think that it would. Wonder what its made out of ?
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
