Nhan` Posted May 12, 2009 Share Posted May 12, 2009 Who here owns a car imported under the 15 Y/O rule? What kind of compliance plate do you have or do you even have one? I spend about 800 fixing my car so it would go through I.D check without a hassle should they put it on the hoist and then the bloke says the car isnt complied and need an application for registration without a plate via a full roadworthy inspection. I've had a look and the car has new seatbelts, side intrusion bars, but no tune specifications under bonnet, tyre placard or 98octane sticker on fuel flap. Has anyone else come accross this problem? Nhan. Link to comment https://www.sau.com.au/forums/topic/269712-compliance-plate/ Share on other sites More sharing options...
scandyflick Posted May 12, 2009 Share Posted May 12, 2009 my celsior was like that. no complicance plate. didnt matter. got sent an id sticker for it after i sold it. i wouldnt worry about it mate. Link to comment https://www.sau.com.au/forums/topic/269712-compliance-plate/#findComment-4590584 Share on other sites More sharing options...
Rocky88 Posted May 12, 2009 Share Posted May 12, 2009 my r32 doesnt have compliance plate either... have to carry an exemtion form with me but otherwise no dramas with regency Link to comment https://www.sau.com.au/forums/topic/269712-compliance-plate/#findComment-4590613 Share on other sites More sharing options...
Dohmar Posted May 12, 2009 Share Posted May 12, 2009 my celsior was like that. no complicance plate. didnt matter. got sent an id sticker for it after i sold it. i wouldnt worry about it mate. I have an exemption sticker too that is affixed to my firewall. My tyre placard is located on the inside of the drivers door sil... never had an issue so far -D Link to comment https://www.sau.com.au/forums/topic/269712-compliance-plate/#findComment-4590762 Share on other sites More sharing options...
Iron Chef Posted May 12, 2009 Share Posted May 12, 2009 Who here owns a car imported under the 15 Y/O rule? What kind of compliance plate do you have or do you even have one?I spend about 800 fixing my car so it would go through I.D check without a hassle should they put it on the hoist and then the bloke says the car isnt complied and need an application for registration without a plate via a full roadworthy inspection. I've had a look and the car has new seatbelts, side intrusion bars, but no tune specifications under bonnet, tyre placard or 98octane sticker on fuel flap. Has anyone else come accross this problem? Nhan. You've done it right, you just took it to the wrong spot. All cars imported under the 15 year rule have to go through a pit inspection before they're registered in SA for the first time. You took it to the place that does ID checks. Link to comment https://www.sau.com.au/forums/topic/269712-compliance-plate/#findComment-4590842 Share on other sites More sharing options...
Nhan` Posted May 12, 2009 Author Share Posted May 12, 2009 but will regency ping me for not having a tyre placard, tune spec sticker, fuel sticker or child seatbelt restraint? I want to make a booking but not if im going to get defected over these petty things. i can get the stickers and what not done but i dont know about the child seat restraint. Any tips? Link to comment https://www.sau.com.au/forums/topic/269712-compliance-plate/#findComment-4591164 Share on other sites More sharing options...
Evil34 Posted May 12, 2009 Share Posted May 12, 2009 but will regency ping me for not having a tyre placard, tune spec sticker, fuel sticker or child seatbelt restraint?I want to make a booking but not if im going to get defected over these petty things. i can get the stickers and what not done but i dont know about the child seat restraint. Any tips? I think i still have the child restraints from my old 32 lying around at home. I will have a look for them and let you know if i find them!!! Link to comment https://www.sau.com.au/forums/topic/269712-compliance-plate/#findComment-4591219 Share on other sites More sharing options...
Iron Chef Posted May 13, 2009 Share Posted May 13, 2009 but will regency ping me for not having a tyre placard, tune spec sticker, fuel sticker or child seatbelt restraint?I want to make a booking but not if im going to get defected over these petty things. i can get the stickers and what not done but i dont know about the child seat restraint. Any tips? My tip is to go down to Regency (the ServiceSA centre) and find out what work you actually need to do before taking the car in for the inspection. If your restraints aren't done, then you'll definitely be sent away and asked to come back for another inspection when all the work required is done. Link to comment https://www.sau.com.au/forums/topic/269712-compliance-plate/#findComment-4591575 Share on other sites More sharing options...
D_Stirls Posted May 13, 2009 Share Posted May 13, 2009 Hey Christian do you know what the go would be with child restraints if you have the car redgistered as a two seater? Surley if you don't have any back seats and say a half cage then you wouldn't be required to have child restraints as they could never be used? Link to comment https://www.sau.com.au/forums/topic/269712-compliance-plate/#findComment-4592349 Share on other sites More sharing options...
Iron Chef Posted May 13, 2009 Share Posted May 13, 2009 My response is that the mounting positions for restraint hooks are also good mounting spots for harnesses In all seriousness, I haven't dealt with that scenario, so I can't give you an answer on it. Common sense would suggest you don't have to bother. Link to comment https://www.sau.com.au/forums/topic/269712-compliance-plate/#findComment-4592444 Share on other sites More sharing options...
Nhan` Posted May 13, 2009 Author Share Posted May 13, 2009 Well I went down there today and gave them my application for exempt of compliance plate. I also had to surrender my I.D check sheet. The roadworthy personel told me a form will be sent to my home address and it would have criteria required for me to pass the inspection and once all is done a road worthy inspection would be carried out. Does anyone have the tune specifications chart that is stuck under the bonnet? i need one as my car does not have one. Evil34 if you have them that would be awesome. Link to comment https://www.sau.com.au/forums/topic/269712-compliance-plate/#findComment-4592968 Share on other sites More sharing options...
JiN_MaN Posted May 13, 2009 Share Posted May 13, 2009 Ring Adelaide Compliance Services, Not sure of his name but the guy was really helpful and provided me with that placard you are talking about. Link to comment https://www.sau.com.au/forums/topic/269712-compliance-plate/#findComment-4593209 Share on other sites More sharing options...
EnFlaMEd Posted May 14, 2009 Share Posted May 14, 2009 (edited) If you took it for an ID check and they told you it needs a road worthy you should receive a statement of requirements in the mail listing what the car needs to have to pass. I am going through this process myself at the moment as I brought a car over from WA which is complied but has no sticker. Edited May 14, 2009 by EnFlaMEd Link to comment https://www.sau.com.au/forums/topic/269712-compliance-plate/#findComment-4594073 Share on other sites More sharing options...
Nhan` Posted May 14, 2009 Author Share Posted May 14, 2009 Do you have the phone number for Adelaide compliance services? im sure my car has been as it has the Vin stamped on an alloy plate on the firewall and has side intrusion bars. Had a tyre placard but has been faded. modded a r33 one and stuck it on there. Link to comment https://www.sau.com.au/forums/topic/269712-compliance-plate/#findComment-4594266 Share on other sites More sharing options...
Evil34 Posted May 14, 2009 Share Posted May 14, 2009 Hey Nahn, I have found the child restraints for your 32, send me a pm and we will arrange to meet up or for you to come pick them up. Cheers Shaun Link to comment https://www.sau.com.au/forums/topic/269712-compliance-plate/#findComment-4594994 Share on other sites More sharing options...
