Nissan skyline R32 GTR
1989 Model
Painted in R34 Platnum Silver
R33 Gtr Wheels
All GTR options,
Inc Electric Windows and mirrors, Climate Control, LSD, Hicas,
Brand new Brake Discs and Pads All Round.
Brand New Battery
Brand New Windscreen with airial
Brand New Timing Belt and Water Pump.
Nismo Lowered Suspention.
Pineapples.
Aftermarket Exhaust.
Custom Grill.
Insurance Approved Immobilser
127,000 kms Engine Has Done 60,000Kms
Comes With 12 months Rego and a Full Roadworthy Certificate.
This is an immaculate example of a R32 GTR .
Price: $ 24,500 ONO
Located in Vic
Serious Buyers only please.
For more information Please call Mick on 0419 153 283.
Edited by MICOLOUR-Mick
https://www.sau.com.au/forums/topic/269878-r32-gtr/
1989 Model
R33 Gtr Wheels
All GTR options,
Brand New Battery
Pineapples.
Custom Grill.
Price: $ 24,500 ONO
Located in Vic
Will you separate the pineapples... Very interested... C'mon you were waiting for it
https://www.sau.com.au/forums/topic/269878-r32-gtr/#findComment-4597474
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
