POLICE are hunting for a third vehicle after a horror high-speed collision between two cars at Woodville North killed one person and injured four others.
Police said drag racing was involved in the crash, at the corner of Torrens Rd and Audley St, Woodville North, at about 8.45pm last night
http://www.news.com.au/adelaidenow/story/0...42-2682,00.html
  • Replies 115
great just what we need more f wits making it hard for the rest of us again . at least the suby was racing another suby and the name skyline isint linked to this crash .
rip to the innocent victim on his way home from work :-(
Once again these f**kwits think it's acceptable to endanger our lives on the road.
When are the authorities going to review legislation and introduce harsher penalties that might actually deter these strett racers.... :(
no shit, now someone minding their own business has been killed, we're gonna be feeling someones boot up our trousers ;|
sad fact is the guy who hit them is still alive... I hope he gets sent to the big house for a while
-D
Stupid, stupid, stupid. :( Custom yellow/lime coloured WRX ... wouldn't be too hard to find that twat.
enuf said
... except R.I.P. to the unfortunate soul.
Edited by RubyRS4
looks like some esl guy wrote that.. so many mistakes its not funny
stupid street racers.. when they gonna learn :S
so you telling me they wernt street racing and they was just driving side by side at 60 ks and the poor toyota just drove out in front of them ?
mey, youd like to think so... they'll just defect more cars...
and beside no law will stop stupid people from doing stupid things...
I was driving home at about 10:10pm last night and had to turn off torrens road as it was shut down,
I work with a close friend of the victum, he left work (we do night shift) at about 12pm when he got a confirmed call that his friend was pronounced dead. WTF is it with WRX drivers? Seriously, one of my best friends was killed by a WRX driver in November 08' (that crash on Taplies hill road), the WRX and skyline on Magill road, and now 2 WRX's this time? WTF! All a bunch of c0ck sucking drop kicks. Low performance drivers in high performance cars.
R.I.P - and I hope a full and speedy recovery to the seriously injured female.
This goes to prove no matter how safe you play life - you still get fcuked over.
Wanna bet? Start by restricting inexperienced drivers getting behind the wheel of high powered cars. They do it to motorcyclists, why not car drivers?
Low performance drivers + high performance cars = FAIL and/or DEATH
We can forget that crap argument about even a datto 1200 can cause death by speed. Its the power of cars like the WRX that can get an inexperienced driver into the danger zone faster and quicker than an NA 1.8lt 4 cylinder Astra for example.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
