Selling my XFX 9800 GTX (http://www.xfxforce.com/en-us/products/gra...es/9800GTX.aspx)
Specs Are on the website.
Completely unopened box.
My old card messed up, and XFX sent me this one as a replacement, but ive got a spare i can use, and arent too interested in computers at the moment. saving for my GTR :(
Asking Price is $300.
I live in Melbourne, South-East suburbs, pick up prefered, but can post at your expense :)
https://www.sau.com.au/forums/topic/270431-fs-xfx-9800gtx/
Your price isn't that great.
A quick look at static ice has them listed starting at $265.
You can even pick up a GTX260 for less than what you're asking.
so why are you commenting at all? if u dont like it, dont waste my time.
static ice also has the same card for over 400$ at several retailers. and? so what?
its easy for u to pick one ONLINE retailer, that is slightly cheaper, which mind you doesnt include delivery AT ALL.
xfx is a more expensive brand name, comes with 2 yr warranty, and is also bundled with Company Of Heroes!
Thats why im asking for $300 dilivered anywhere in aus, as it is 100% brand new unopened.
Mods please do something warn/watev the user as his post does not follow the topic guidlines set out in the STICKY....
thank you
Edited by ShiftyTys
https://www.sau.com.au/forums/topic/270431-fs-xfx-9800gtx/#findComment-4612192
What model is it? The XFX link you posted has 7 different models listed on the site.
Why do you want to know your clearly not interested. ill answer that question to genuine buyers in PM if they ask.
https://www.sau.com.au/forums/topic/270431-fs-xfx-9800gtx/#findComment-4612269
Good luck selling it with that attitude.
Your comment about the card being listed for over $400 on static ice is irrelevant as far as I am concerned because you haven't posted the model number of the card.
well, considering all three types are above 360ish, standard, xxx, and black edition.. its very relevent.
do me a favour and please get off my post. your here to stir trouble... next step i go straight to a mod and request you get delt with...
thank you
https://www.sau.com.au/forums/topic/270431-fs-xfx-9800gtx/#findComment-4612407
what model is it? 9800gtr ________?
9800gtx
Pv-98F-YDF9
The other models are an overclocked version of this one. The last time I bought a factory overclocked card. It played up. So standard is the go. N clock it yourself. Lol
Thank you.
https://www.sau.com.au/forums/topic/270431-fs-xfx-9800gtx/#findComment-4628486
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
