Girlfiends little mirage is using heaps of oil? normally holds around 3.3ltrs but the last 2 services ive done on it ive only taken out about 1.5ltrs?? A coulpe of times ive had to give it a massive top up because the engine light has come on. Took the plugs out on the weekend and they where all fouled with burnt oil and gunk.
i service it every 5000km started with 10w-40 oil but moved up to 15w-40 becuase of the oil loss.
Car has done around 170000kms
Any ideas on why this keeps happerning any help would be great
Thanks.
https://www.sau.com.au/forums/topic/270603-98-mirage/
I've noticed the same thing with the GF's Corolla, 10 or so years old, 140000km and burns oil like no tomorrow! pretty sure that one has 20w50 (albeit cheap shit united brand oil lol), not sure about when it had a proper service last, it blows a heap of white oily smelling smoke on cold start then is fine as far as I can tell. Surely plugs wouldn't make that much of a dramatic difference?
https://www.sau.com.au/forums/topic/270603-98-mirage/#findComment-4602065
It really depends on how it was serviced in its life. Heck my corolla is now knocking on 300000 km with original engine. Just done a new water pump ( old one started leaking - Bastard to replace ) and a timing belt for good measure. Thing only uses a litre every 5000 + kms and not all of that is getting past the rings. Crank seal is leaking . Yet some pretty new cars you see these days are churning out Blue smoke when the car is less than 5 years old.
https://www.sau.com.au/forums/topic/270603-98-mirage/#findComment-4602092
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
