hi everyone.
just wondering wher i can find a jun r33 kit. been looking everywhere and found a few but there cheap ones that dont line up properly.
need help and opinions.
most fibreglass copy kits won't line up properly and will most likely need some sort of pre-fitting as far as im aware
i just got some stuff from monkey warehouse, its a pretty good fit imo, some bits need a bit extra fibreglassing here and there though
https://www.sau.com.au/forums/topic/270887-jun-r33-kit/#findComment-4606363
