ColdFusion Posted May 20, 2009 Share Posted May 20, 2009 (edited) Hey guys. I've snapped two studs on one of my spacers and I've been trying to find something that will fit, but so far been unsuccessful. The places I've looked only have the 'Nice Products' range of studs and the closest is just a bit too big. First one on this page http://www.niceproducts.com.au/catalogues/wheel/wheel18.htm is the closest, but the knurl diameter is slightly too big at 12.9mm (the part with the straight lines). Needs to be about 12.2-12.3mm. I bought one to try but the hole is too small for even the first part of the shoulder to go through. Does anyone here know of a different brand that may fit or even someone who has replaced them before? If I can't find anything I guess my best bet would be to slightly enlarge the hole so it does fit. I can't see any real problems with doing this as it's only a small amount of material being removed. Edited May 20, 2009 by ColdFusion Link to comment https://www.sau.com.au/forums/topic/270999-replacement-wheel-studs-for-spacer/ Share on other sites More sharing options...
R DIRTY 3 Posted May 21, 2009 Share Posted May 21, 2009 In the past i have taken broken studs to Mr Mag and places like that who can normally match them up. I believe Coventry's sell studs as well and as long as they are on display at the store you go to you stand a chance of finding a match. If you rely on the parts monkeys at the counter of Coventry's store to match it up for you, it will probably be deemed too hard and they 'wont have anything to match' etc coz they cant be bothered. Link to comment https://www.sau.com.au/forums/topic/270999-replacement-wheel-studs-for-spacer/#findComment-4607590 Share on other sites More sharing options...
gazza750 Posted May 21, 2009 Share Posted May 21, 2009 repco sell studs Link to comment https://www.sau.com.au/forums/topic/270999-replacement-wheel-studs-for-spacer/#findComment-4607936 Share on other sites More sharing options...
ColdFusion Posted May 21, 2009 Author Share Posted May 21, 2009 I'll give Repco a try. I've tried AutoOne and the Coventry's in Kelmscott, but both only had the book to go off. Bought the test one from AutoOne. Which Coventry's has studs on display? Link to comment https://www.sau.com.au/forums/topic/270999-replacement-wheel-studs-for-spacer/#findComment-4608896 Share on other sites More sharing options...
double d Posted June 20, 2009 Share Posted June 20, 2009 talk to kev at imparts in osb park 94449761 Link to comment https://www.sau.com.au/forums/topic/270999-replacement-wheel-studs-for-spacer/#findComment-4667993 Share on other sites More sharing options...
