Hi all, can someone help. I have a 4 door r33 GTST and my horn goes off 90% of the time when i turn a corner. Its sooo embarassing, i went to the shops the other day and some poor old lady was loading up her shopping in the boot of her car and as i turned to park behind her the horn went off, i swear she had a heart attack. She went off at me hahaha, i calmed her down and told her the problem and she ended up in fits of laughter at me telling me to get it fixed. I just dont want to get pulled over by the cops for undue horn noise. If someone can point me in the right direction it would be great ta, as i have read the topic from 2004 and it wasnt much help.
https://www.sau.com.au/forums/topic/271076-help/
same thing happened to me the morning of last years new years eve... left a party at like 7am... made a LOT of enemies :sick:
I found out that the plastic holders that hold the metal weights in place to balance the steering wheel had broken and the metal weight was earthing the horn, making it go off...
can you hear a rattling in your steering wheel at any time?
https://www.sau.com.au/forums/topic/271076-help/#findComment-4608521
same thing happened to me the morning of last years new years eve... left a party at like 7am... made a LOT of enemies :(
i sure can and ur right the weight is loose, i have no idea why its there so i just put it back in :sick:
https://www.sau.com.au/forums/topic/271076-help/#findComment-4608524
Bingo!
You can take it out if you want, just don't get yourself into any drift comps :(
Steven, out of curiousity ... and purely because I haven't a clue ... what are the weights in the steering wheel for? :sick:
https://www.sau.com.au/forums/topic/271076-help/#findComment-4608533
Apparently to make it uniformly balanced.
They don't, and the standard wheel is shit... it's not even mounted perfectly in the centre!
But to be honest I'm just fussy :(
CHEERS !!! ill give it a go just dc the battery now ...... i had to go get the tamper proof bit tho and that was a headache in itself grrr
am i able to maybe use some electrical tape to hold it in place ?? I know its dodgy but it might be a bandaid job for now.
So how do i get it fixed properly ?? :sick:
https://www.sau.com.au/forums/topic/271076-help/#findComment-4608560
Buy a new steering wheel would be the proper fix, but taping it up and putting the airbag back on will be a good enough fix that you probably own't ever think of it again :sick:
Maybe check out some info on taking the steering wheel off cause it can cause airbag and HICAS errors if you do it wrong. Point of advice, don't connect the battery while you'r doing it at any point, make sure it's all back together when the battery goes back on.
I don't think it dampers, it would seem a bit weird to put weights in an already heavy steering wheel just for that...
https://www.sau.com.au/forums/topic/271076-help/#findComment-4608569
Buy a new steering wheel would be the proper fix, but taping it up and putting the airbag back on will be a good enough fix that you probably own't ever think of it again :P
I already have taken it off because i took it all apart and it all looked fine and no loose or easy bendable wires and so i put it back together in the hope that i had disturbed something enough that it would be fine, but no such luck as i went for a drive and still the horn went meeeeeeeeeeeeeeeeeeeeep :sick: I thought about going for a drive without the air bag connected but i thoght better of it :( cheers for ya help and im sure i will be back in a minute or 5 if the weight wasnt causing the prob
CHEERS for the mo :D
https://www.sau.com.au/forums/topic/271076-help/#findComment-4608602
I already have taken it off because i took it all apart and it all looked fine and no loose or easy bendable wires and so i put it back together in the hope that i had disturbed something enough that it would be fine, but no such luck as i went for a drive and still the horn went meeeeeeeeeeeeeeeeeeeeep :P I thought about going for a drive without the air bag connected but i thoght better of it :) cheers for ya help and im sure i will be back in a minute or 5 if the weight wasnt causing the prob
CHEERS for the mo :)
Dont quote me on this, as I dont know for sure (and dont even own a R33) but I heard if you disconnect the airbag with the battery connected the light will come on and never go off.
Edited by 93GTST
https://www.sau.com.au/forums/topic/271076-help/#findComment-4608723
That would sound right in any car with a airbag i would say. As it would be saying there is either 1. a problem with the airbag that needs to be checked by a pro, or 2. it has gone off and needs to be replaced/reset by a pro.
So if you disconnect the battery, the ECU or whatever wont be running to detect if it has or hasn't been tampered with.
https://www.sau.com.au/forums/topic/271076-help/#findComment-4608928
I had this issue when I put a aftermarket steering wheel on my old car.
Turned the wheel and the horn stayed on.
One night, I turned out of BP on Brighton road, and beeeeeeeeeeeeeeeeeeeep went the horn and I had a bunch of guys in BP come out and were screaming at me and started running after my car! It was crazy!
And trying to park in shopping centres, yeah that was fun. Especially in the under-cover car parks haha.
https://www.sau.com.au/forums/topic/271076-help/#findComment-4609025
Thanks to everyone that pitched in :)
Special thanks to DRD OOF ...... it seemed to work :) YAY !!!
BUT WHY !!!! would u not disconnect the battery before u muck around with the air bag ???
You must want a bag in ur face and im not talkin about fun ones either sheeesh :P
https://www.sau.com.au/forums/topic/271076-help/#findComment-4609074
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
