  • Replies 197
Friday 26/06/09
19:00 RS73
19:30 Shanusr33
20:00 NZMO
20:30 Ashneel
21:00 RBPOWA
21:30 B3ZA
22:00 blk_sz
22:30 GotOne
23:00 Emsta
23:30
Saturday 27/06/09
19:00
19:30 krzysiu
20:00 LEANBAC
20:30
21:00
21:30
22:00
22:30
23:00
23:30
Friday 26/06/09
19:00 RS73
19:30 Shanusr33
20:00 NZMO
20:30 Ashneel
21:00 RBPOWA
21:30 B3ZA
22:00 blk_sz
22:30 GotOne
23:00 Emsta
23:30
Saturday 27/06/09
19:00
19:30 krzysiu
20:00 LEANBAC
20:30 Halle
21:00
21:30
22:00
22:30
23:00
23:30
:plz no rain.
Actually - i change my times guys - fridya is too late, going sat instead see below
Friday 26/06/09
19:00 RS73
19:30 Shanusr33
20:00 NZMO
20:30 Ashneel
21:00 RBPOWA
21:30 B3ZA
22:00 blk_sz
22:30 GotOne
23:00
23:30
Saturday 27/06/09
19:00 eMsta
19:30 krzysiu
20:00 LEANBAC
20:30 Halle
21:00
21:30
22:00
22:30
23:00
23:30
Friday 26/06/09
19:00 RS73
19:30 Shanusr33
20:00 NZMO
20:30 Ashneel
21:00 RBPOWA
21:30 B3ZA
22:00 blk_sz
22:30 GotOne
23:00 MattD
23:30
Saturday 27/06/09
19:00 eMsta
19:30 krzysiu
20:00 LEANBAC
20:30 Halle
21:00
21:30
22:00
22:30
23:00
23:30
Friday 26/06/09
19:00 RS73
19:30 Shanusr33
20:00 NZMO
20:30 Ashneel
21:00 RBPOWA
21:30 B3ZA
22:00 blk_sz
22:30 GotOne
23:00 MattD
23:30
Saturday 27/06/09
19:00 eMsta
19:30 krzysiu
20:00 LEANBAC
20:30 Halle
21:00 pharoahs33
21:30
22:00
22:30
23:00
23:30
Simple background. I found that the less distracting the background, the more your car stands out. Unless the Bolte Bridge has some sort of deep, intrinsic significance to you, that is... :happy:
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
