I didn't check for a couple of days and lost the cup holder?That's bad...well,let me know if the sale fails and send me a pm...Thanks
  • Replies 73
Heya Mate
how are the front and rear disks and pads? Any chance of getting the disks measured? I'm in desperate need - my disks are paper thin! Also - was this an RS4 V? Or a RWD model? As it seems the AWD and RWD versions have different disks.
Cheers
Aaron
Its a AWD I will get some measurements on the disks for you asap.
interested about the exhaust and weathershields of both side, have u got any pics? how much will it cost to send to 3131? thanks mate
exhaust still on car here are what photos I have, only have the passenger wethershield..
freight $50 by courier for exhaust
have you got photos of the weathershield? I still interested even only the passenger side
how much you want for the weathershield? Is it not broken at all, right?
I am still interested about the exhaust, have you got any pics when it is out of the car? I assume it is a turbo back one from the front pipe, right?
thanks
thanks
$50 weatheershield no cracks do have another guy interested also
exhaust is still in the car, may have it out next week..its only a cat back but i do have a front pipe i was going to use but not now for extra $100 so $450 for complete exhaust..
Wrecking 1998 Stage series 2 most parts available
I hope no one was hurt in the accident. Do you have the centre console vent garnish (grey in colour, above the climate control) for sale? Mine's cracked after some idiot (not me ) tried removing it, most likely with a crow bar and a mallet.
hey mate
yep i have thne grey has the vents in it $25 + post
  • 3 weeks later...
  • 2 months later...
Hi mate, any chance you might still have the LHS black mounting arm for the side mirror (happy to buy whole side mirror)? I snapped mine in 2 while moving house... I'm in Brisbane and happy to pay for freight if you've still got it.
Hey mate
sorry sold it alreadya while back
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
