allright, i am completly stripping the inside of my 33, apart from a few bits n peices.
rear seats $150
seat belts $150 for all
the ceiling $75
rearview mirror $20
door trims $150 each
rear trims $100 each
all the pillar trims except the left hand front $100 for all
7 inch touch screen dvd player $350
2 6 inch mtx speakers $40
items that will be removed pending interest
complete dash $500
centre console including the dash surround and little middle glovebox thingo $200
front seats $200 each
all items are plus postage, all items are in perfect condition, purchase of multipal items reduce postage.
if i have forgot anything that you want, just ask me :)
https://www.sau.com.au/forums/topic/271405-stripping-the-interior-of-my-33/
bump
any offers?
i am very flexy so hit me up with offers on whatever you want.
i amvery keen to get rid of all of this stuff so please help me get rid of it.
i can supply lots of photos of whatever you want so just ask!!!
I WANT TO SELL THIS STUFF!!!!! OMGBBQ
add to the list.
2 rear gas struts for the boot $20
rear wiper arm and motor and blade, everything $40
air con control box thingo $30
clock $10
the interior lights on the roof, front and middle $15
and there is other stuff that i cant think of, but let me know if you want anything
i want to sell this stuff, so kindly buy it
i have the gear stick surround but the ashtray is rooted, but the face plate is still there so if you dont smoke its good for you and it looks normal, and it has the 12v socket also.
is that what your after?
$50 including postage
hey bro where abouts are you located and if u want to sell the right door trim for $100 cause thats all i can really afford right now then give me a heads up and i'll get back to you.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
