Hi all, i have a OEM PVC ORIGINAL r33 gtst series 2 front bar for sale of a 1996 model in sonic silver, (stock series 2 color)
PRICE: $300 Or best Offer (Or will trade for a SERIES 1 400r front bar with built in grill or a vielside front bar with grill, i will give extra cash if its worth it..
CONDITION: NO CRACKS, NOT OUT OF SHAPE, NO CHIPS IN THE BAR Only some paint chips and some scuffing under the bar, everything working.
REASON FOR SELLING: I am puting on a aftermarket bar. I also have series 2 headlight now, so this dioes not match up at all..
Here is a pic of the front bar that i found on my pc from 1 year ago, there are a little more paint chips around the same area on the picture. I would recommend a respray though.. you can see some of the black undercoat were the chips are...
I will get more pictures up... just message me for a certain picture if needed..
The bar is still on the car at the moment..
If needed i can setup a time and place to inspect the bar if needed..
https://www.sau.com.au/forums/topic/271521-r33-gtst-series-2-front-bar-oem/
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
