item 1. apexi rsm black
been in car not that long, very good condition pretty much brand new. comes with all wiring, apexi stand(glare, so you cant see 'apexi' in the pic), box and manuals (not pictured). black in colour, lights up white. asking $250
item 2. MV Automatics stage 2 shift kit
only had in the car for a couple of months. can supply receipt at request $300
item 3. MV Automatics 2800/3000rpm stall converter
item 4. nismo momo gear selecter.
good condition with only wear to the top button which can be sprayed anyways $200
item 5+. 2 automatic gearboxes.
in working condition. only comes with 1 valvebody and 1 stall converter though. just need them gone. $250 the both
might have some automatic interior plastics and cluster (107,xxxkm) and a PWR transmission oil cooler for sale if anyone is interested
might be interested in swaps for white defi racer gauges - oil pressure, oil temperature, water temperature. black rays wheel nuts. bride er34 gtt passenger rails to suit bride brix 2 or Nismo Urethane. GT Shift Knob cash adjustment depending on item
sms or call me on 0432454695. please dont pm as my computer is nuts and wont allow me to pm.
Edited by john-e boi
hi im interested in the shift kit, just wondering i do a bit of heavy traffic driving and was wondering does it feel too rough when its changing the gears while in traffic?
thanks.
scott.
thanks.
scott.
its abit rougher than stock, nothing too unhackable though.
hey mate keen on the stall converter.
would be going in an r33 series 2 though. i would imagine that it would still fit?
can you confirm this?
Cheers
wouldnt have a clue to be honest mate.
bump. take rsm, hi-stall, shift kit, shifter, and will chuck in trans oil cooler and postage for $1050
shift kit and hi-stall has been barely in use, car been off for since installed.
everything needed gearbox wise for a low 12second pass and possible high 11 with stripped interior and drag tyres
bump. $800 for the lot. stage 2 shift kit, hi-stall converter, standard stall converter, standard valve body, nismo momo shifter, PWR trans oil cooler. take them away
yeah still got the lot. need to get rid of them. if you're happy to take the lot ill let you have them for $550. cooler, shift kit, stall converter and shifter. enough for me to get a koyo radiator. =)
Sorry mate. $550 is rock bottom.
Postage i'm guessing about $80? Shift kit and stall converter is quite heavy, especially the stall.
It's only been in the car for 50km if that so I can't really tell you guys what it's like to drive in traffic with these installed, but from what I have researched before performing the mods, it's not much different during traffic and normal driving. The people installed the shift kit and stall converter messed something up, refused to admit to fault and car was off road ever since. It was an electrical problem. Car would start up alright, drive alright, until it goes to shift into 4th, A/T light would pop up and go into limp home mode (selecting 3rd gear only). Both items has been bench tested multiple times (was at 5 other different automatic specialists after it was installed), as well as re-installing standard parts back in and still had the same problem occuring.
Both items are MV Automatics items, highly regarded by many especially within the skyline community. My car has since been converted to manual so I'm just counting my losses now, and just want to sell these parts enough for a Koyo radiator. With the shift kit, stall converter and trans oil cooler, the gearbox was built with the thought of a high 11seconds 1/4mile pass. Shame it will never happen.
Prices are still:
shift kit : $300
stall: $300
gear selecter: $100
trans oil cooler: $100
If someone is willing to help me out by buying the whole lot, im willing to let it go for $550 and if you're picking it up ill give you a standard valve body and stall converter (spares). Your automatic will massively benefit with better performance without harsh unbearable conditions.
Also for those that might be interested. I have:
r34 gtt automatic standard radiator cracked where the radiator cap is (repairable)
r34 gtt automatic standard transmission oil cooler
that someone can have for free if they want to come pick it up
Also might have for sale soon:
r33 gtst automatic standard radiator. still in very good nick, no leaks or rust. Will post up once i get a performance radiator
r34 gtt automatic steering wheel. only very slight marks. Will be available once I receive my R34 GTR steering wheel. Apparently a good upgrade for r33's.
Please call/sms or post up on here. PM's will take longer to be responded to.
where in melb are you located? you can pm me that if you like.
im happy to take the shift kit and cooler and pay in cash. unfortunately i just dont think i need a stall converter because im not aiming to go drag racing.sorry.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
