hey all,
can any one please confirm the below, i've been curious!
what is the stock boost level for a 33 gtr? 10 psi or 12 psi?
the mechanic advised that he raised the boost to 12 psi on my car when i had my power fc installed, however the below advises that stock is 12!!? been playing on my mind the last few days.
any info would be appreciated.
thanks!
R32 GTR's are lighter, so there is less weight to push.
From memory I read this from some where...
R32 GTR = +0.7 (10.9 Psi) Bar Boost (Stock)
R33 GTR = +0.8 (12 Psi) Bar Boost (Stock)
R34 GTR = +0.9 (13 Psi) Bar Boost (Stock)
Edited by KR4-GTR
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
