Gday
Just after some info on the cost of getting a timing belt replaced as mine is now overdue..... just looking on ebay there are HKS ones for 150 and then their are some generic ones for 70... is it worth paying the extra or are these HKS one aimed at worked engines.
Also i read somewhere that if im doing the belt i mite aswell do the water pump which again on ebay are around 200 buks... does this sound right
and while im at throwing in some adjstable cam gears would suit nice...
anyways how much would a time belt change and water pump cost for just the labour ... it looks expensive (having to remove the intercooler piping, radiator etc
thanks for ur input
https://www.sau.com.au/forums/topic/272319-timing-belt-cost-cam-gears/
Which engine is it for bud?? Its prob worth grabbin a Gates Racing one for about $100 and something bucks.. As for waterpump, If its an RB20 just grab an RB30 one...70-100 from your local Repco/Autobarn.
Also if your belt hasnt been changed before, It may be worth changing the idlers/tensioner too, if you decide to change them you can get a Dayco Timing belt kit for sub 200bucks from your local BSC or a Gates one from CBC (unsure of price) .
As for labour, I reckon a decent shop would charge $700+ inc parts for this sort of service. Or if your handy with the tools, 2-3 hours of a weekend is all it will cost you... Theres a good Tute on this site if you need help.
Also if your getting adjustable gears, factor in the price of a tune too. I know alot of people just throw em in and hope for the best, But if your gonna do it, you might as well do it properly and make sure your making more power- not losing it!!
Hope this helps,
Ben
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
