4 door love Posted May 29, 2009 Share Posted May 29, 2009 i have blown the 20 in my 32 up and have now decided to put a 25neo into my car as i managed to score it cheap. now when i put the engine in, will everything line up as it did with the 20 in the car ie. gearbox xmembers and the such i have read that when putting a 25 into a 32, you retarded the exhaust cam 8 degrees. can anyone confirm this. hopefully thats all i can think of now. cheers Link to comment https://www.sau.com.au/forums/topic/272345-converion-queries/ Share on other sites More sharing options...
N-DAWG Posted May 29, 2009 Share Posted May 29, 2009 ECU. You've got a higher capacity engine, larger injectors, the NEO has a few extra things like a variable valve in the intake plenum. Assuming you're replacing with an RB25DE NEO not RB25DET NEO? Link to comment https://www.sau.com.au/forums/topic/272345-converion-queries/#findComment-4625441 Share on other sites More sharing options...
4 door love Posted May 29, 2009 Author Share Posted May 29, 2009 im putting in a DE neo. it comes with the ecu and everything that will be needed Link to comment https://www.sau.com.au/forums/topic/272345-converion-queries/#findComment-4625674 Share on other sites More sharing options...
BezerkR32 Posted May 31, 2009 Share Posted May 31, 2009 put cam gear on it and set it up on dyno. 10deg sounds excessive and the fact its in a 32 wont make a difference. but you never know. im putting in a DE neo. it comes with the ecu and everything that will be needed Link to comment https://www.sau.com.au/forums/topic/272345-converion-queries/#findComment-4627401 Share on other sites More sharing options...
