Hey all was wondering wat turbo would be better for a street application wit the ability to goto the track an tear it up on a weekend?? i currently have the gt2860 (-7) an am makin 450hp atw.. are they capable of more?? cause they have amazing response an make a nice street car.. or would it be appropriate to bump up to something bigger such as the gt-rs! to see atw figures of 500-550hp. An are the gt-rs really as laggy as ever1 makes them out to be??
thanks korey
https://www.sau.com.au/forums/topic/272485-gt2860-7-gt-rs-or-gt-ss/
Are you on a stock stoke 26? If so i dont think RS's would be the right turbo for a street set up. Even myself on a high compression 2.8 litre im sometimes wishing for slightly smaller turbo's because im caught "off boost".... Gets retuned this week so see how much better it is. 2530's at the biggest on a stock motor IMO.
Well that was the other option the hks stroker 2.8lt, but your sayin that your even caught off boost occasionally wit that set-up?? i was talkin about the 2.6 but strokin it was another option if i went the Gt-rs.. wat are the 2530's equivelent to?? the gt-ss?? the gt2860's are slightly larger yeah? with the set up your runnin being stroked wat rpm is boost coming on wit the gt-rs's on??
Last tune it was 1.65 bar at 4700 RPM. However, I will reply again on friday and its getting retuned. Alot of stuff has changed (catback, plenum, boost controller, better cat) so I have a feeling this will drop a few hundred RPM. The catback made a HUGE difference (kakimoto Full Mega N1) Its going as good as what it was before on 1.3 bar. Going up a hill in 2nd gear with 3 people in the car and jump on the loud pedal at 6500 RPM and it will break traction. Give me 5 days :(
Mate - ive said before... Please use the search.
GT-SS, GT-RS and every other bolt on turbo from garrett/hks for a RB26 is soooo well covered you really need to do a bit of your own homework rather than have people spoon feed you.
Once you do search, you will find there is a turbo in between GT-SS & GT-RS - The Garrett "-5"/HKS 2530... more info on that specific turbo than any other on the forum
Thanks.
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
    • I’ve read the previous posts so just looking for latest information on how people have dealt with front facing plenum is it a defect etc or didn’t pass roadworthy or was it not noticed? Have a r34 and deciding if I should make a hole on the driver side or not.  I know some people have said blitz return flow but I might get rid of the stock intake down the line for a plenum so I rather set up for that now plus I already have a standard Intercooler. Car is mainly stock  Thanks.
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
    • Wrong side of sydney for me coming from Goulburn, but you should head along, all ages of Skylines will be very welcome
    • Yeah so physically that port is consult not OBD2, but also be aware that "JODB" is not really a thing - it came in around 2000(ish) but is not a standard like ODB is, each manufacturer had differences. If you are looking at ECU only and have a standard ECU, go with Datascan as Turbo Tapin said. Per another recent discussion here thought that won't do other systems like in a modern car, for example bleeding ABS
