Got the Sh%#$ with the crap laying around in the shed and spare room, so I went nuts taking pics and want to get rid of the stuff.
Pretty much all this stuff is just make an offer or free. I've got prices in mind for some things, but I'll see what happends.
Stock R33 GTS-t intercooler
http://home.iprimus.com.au/jayson77/parts/cooler.jpg
Stock R33 GTS-t dump + front pipe + heat shield.
Also front pipe piece (pretty dodgy) no back flange - for free !
http://home.iprimus.com.au/jayson77/parts/exh.jpg
Stock R33 GTS-t clutch fan + fan + shroud (shroud has had the top cut slightly) - clutch fan and fan SOLD
Stock paper filter for R33 GTS-t airbox. Only done about 3000km.
http://home.iprimus.com.au/jayson77/parts/filter.jpg
Standard R33 GTS-t Cat converter. Works fine, not clogged etc. - SOLD
Front brake pads for R33 GTS-t – pretty sure they are stock ones. Heaps of meat left on them.
http://home.iprimus.com.au/jayson77/parts/pads.jpg
Interior light from R33 GTS-t. Has slight crack in it.
http://home.iprimus.com.au/jayson77/parts/light.jpg
Misc suspension bits for stock suspension on a R33 GTS-t
http://home.iprimus.com.au/jayson77/parts/susp.jpg
http://home.iprimus.com.au/jayson77/parts/susp1.jpg
90 degree 2 1/2 inch rubber bend. One clap fits it, the other is a bit small. SOLD
Twin air horns - SOLD
2 gold fuse holders, one of is mountable, comes with one 60amp fuse and a few metres of cable.
http://home.iprimus.com.au/jayson77/parts/cable.jpg
27mhz President Adams CB. 40ch, AM SSB, modified for extra power, 7khz slide (moves between channels !).
Pearce-Simpson Cub, 40ch AM only.
SWR + Matcher for 27mhz. Handle upto 100w.
http://home.iprimus.com.au/jayson77/parts/cb.jpg
Electrophone 27mhz CB – probably good for parts (if your keen !)
http://home.iprimus.com.au/jayson77/parts/cb1.jpg
27mhz SWR meter
http://home.iprimus.com.au/jayson77/parts/cb2.jpg
Ultrasonic (or microwave??) module for Moss Alarm. If your good you could modify it to suit different alarms.
http://home.iprimus.com.au/jayson77/parts/ms712.jpg
Spot light – 750,000 candle power !! great for spot light shooting, or blinding the fools that refuse to dip their lights !! - SOLD
Rear (or front! Can’t remember) Lovell sway bar for a Datsun 180b !!! Don’t laugh ! Never used….
http://home.iprimus.com.au/jayson77/parts/sway.jpg
MISC stuff below….
Kenwood home graphic (old).
http://home.iprimus.com.au/jayson77/parts/graphic.jpg
Desktop charger for Nokia 8250. Ear piece for 8250. And never used Nokia 3210 covers.
http://home.iprimus.com.au/jayson77/parts/phone.jpg
Spear gun, double band, two heads - Back for sale
Video sender – sends about 5-10 meters at the most !
http://home.iprimus.com.au/jayson77/parts/video.jpg
¾ yard glass !! used once at 21st. Still has all the packaging…
http://home.iprimus.com.au/jayson77/parts/yard.jpg
Happy to send interstate if REALLY keen !!
J
https://www.sau.com.au/forums/topic/27254-fs-make-an-offer/
White 32 - yepp, the bend will slip straight onto a 2 1/2 inch pipe. The inside diameter of the bend is 64mm. Just note that one clamp fits it, but the other is too small, but I'll throw in both.
No problems about sending it to you COD, can send off Monday lunch time.
Make an offer for it :(
J
https://www.sau.com.au/forums/topic/27254-fs-make-an-offer/#findComment-573757
  • 1 month later...
  • 1 year later...
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
    • ^ This. The mode door actuator is a common failure, as is the actuator and/or the actual valve for the coolant flow control valve. I also don't know how available the mode door actuator is these days. I've been meaning to look into it and get one from wherever is possible, to keep in the shed for the rainy day when mine eventually fails. Anyway, the advice to you is to search the usual NOS part supply places, or even just go to Nissan and see what they list.
    • Have you got a pic of the actuator? My guess is that unit has failed internally and was flopping around, so the previous engineer who owned it forced it to be fully open to cold air (blocking the heater core path). As far as you can tell, is anything else wrong in the system? Likely you just need a new actuator (not sure how available they are) and then "installation is the reverse of disassembly"
    • I'm happy with the Lsailt unit that I put in, it puts full Android on the top screen so you can run whatever Nav and other Apps you want, while still existing inside the factory functionality like automatic reverse cams, audio input switching, retains factory bluetooth etc. Not cheap and the install was moderate (not simple, not hard) Yours is a V36 not V37 though right?
    • Yeap, all the NC's that I originally looked at that had a hard top were PRHT, which makes the roof line look horrible, hence why I said nope to them My only caveat for another MX5 was it needed to have a hard top, and initially I didn't think you could get a detachable hard top for the NC,  like my NB had Again, a big thanks to Matty for helping me source the detachable hard top for my little girl, they are as rare as hens teeth in Australia, and the few people who have them, keep them Also to Greg, for initially pointing me in the NC direction NC PRHT 🤢🤮 Not mine (I really should take more photos of my car), but a NC with the detachable hard top 😁 To me, the difference in how the detachable hard top roof line looks, and how it actually follows the bodies lines, like they do on NA's and NB's, is chalk and cheese compared to the bulbous looking PRHT
