  • Replies 55
^^ Hmm. In my case all the internal stuff was out of a almost brand new Series 3 box which had 11,000 KMS on it. It was purchased in may/ june 2006 from Just Jap. You would think that I would have the lastest revision in my box at the moment. and I cant see it being worn that much after so little work to require a new one.
Your right mate, you should have the latest synchro setup. You gotta ask yourself, is it really that bad you want to pull the box down ? Maybe your a harsh shifter ? has it been like this since day one with the OS ?
Since the first time i drove it. It doesnt matter if i shift hard or not as it is there under power in 3rd gear only. After smashing a box im the biggest fairy with shifting!
I got a call from a bloke in England who has exactly the same issue at exactly the same speed. He has done 12,000 kms on his box and has run a high 10 @ 135 ish MPH, so making a fraction more grunt then me. He hasnt broken it yet, so i might just put up with it. Only time will tell.
  • 3 years later...
hi paul,
i just came across this thread - 4yr thread bump :)
how is your box holding up & that 3rd gear vibration?
is anyone else still having 3rd gear vibration symptoms & any subsequent updates since?
Well while the car was apart I had it pulled down and rebuilt. The vibration is still there, but no where near as bad as what it was. When the new rear diff goes in illl be putting in solid alloy bushes. See is that has any effect on it.
Did u end up changing any parts during the rebuild or balance any of shafts?
This intrigues me and I'll explain why. My mechanic changed my clutch and as soon as this was done, 3rd gear vibration became apparent under load and boost. With the old clutch, it was perfect.
I called Terry @ Award Diff and explained the symptoms my car was having and he bluntly said "its your spigot bush" which makes perfect sense to me as it was obviously damaged during the r&r (before I changed my clutch, there was no vibration). He explained it is something to do with 3rd gear running on the same shaft / input shaft. I can't remember the exact explanation BUT he was adamant and this is why the issue is there only in 3rd gear...under load 3rd gear vibrates due to loose tolerance between input shaft and spigot.
Have u replaced your spigot?
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
