  • Replies 97
can i get a price from and rear a1mrs for r33 gtr brembos
Hi mate,
A1RM to suit Brembos are $179 per axle set, and both front and rear now in stock!
Regards,
Greg
More positive feedback from HPX users!
HPX Pads received Greg- fantastic delivery speed!!
Bedded them in last night and i can say i'm VERY impressed. They have more bight and better co efficient than the RB74's i was previously using with better pedal modulation.
http://ozvr4.com/forums/showpost.php?p=128...p;postcount=134
QFM HPX Pads Fitted To An Import Legnum VR4!
Got my HPX pads bedded in now and they are very impressive. Progressive and pull up very smoothly, or VERY quick if you really want. They also produce stuff all dust and aren't noisy at all with my slotted rotors either. For the money these are excellent pads and much more confidence inspiring than the crappy pads that were on for compliance.
http://ozvr4.com/forums/showpost.php?p=128...p;postcount=136
Another case of QFM A1RM for the win!
The QFM A1RM pads were a huge step up in pedal feel and control-ability...No more dead pedal, locking, ABS interference etc. The HPX pads I know nothing about but heard good things.
IMHO, if your ever doing a track day or maybe just hard driving, A1RM are the way to go...
http://www.opelaus.com/forums/showpost.php...mp;postcount=19
Hi all,
Just to let everyone know we've now started getting through our first batches of QFM pads to suit Series 2 Stagea Fronts!!! After we sent out the paid pre-orders yesterday, we've not got 1 set of A1RM ($179) and 2 sets of HPX ($119) left. These will go quick, but there is a heap more on the way!
Quick run down on the pads:
HPX: Bendix Ultimate equivalent, very low dust and rotor wear
A1RM: Ferodo DS2500 equivalent, again, with relatively low dust and rotor wear given the performance
To order, just swing me your details, full name, delivery address (preferably a work or business address!!), contact number and email and I can fire you through an invoice with direct deposit details, or else credit card over the phone is also available. Shipping Aus wide is $8.
As usual, any questions, feel free to give us a bell, 1300 884 836, or email sales at gslrallysport dot com
Regards,
Greg
QFM HPX on a VS Ute!
Well the QFM HPX BRAKE PADS are bedded in and I`m very happy with them.
I can really feel the better braking performance.
http://www.brisbanecommodore.com/bccc/show...amp;postcount=2
QFM A1RM!
The pads are mostly bedded in and I must say that I am VERY impressed.
Even when I was doing the progressive bedding (60-20, 80-20) they pulled up extremely well.
Very happy, will buy again!
http://www.boostcruising.com/forums/index....mp;p=1284761614
What else can you say?!
I have the A1RM's and these are by far and away the best "serious use" pads I have tried, bar none!!! If you want a high performance or track day pad these are the way to go!!!
In the SRi-T I tried EBC Green, EBC Red's, EBC Yellow's, Pagid, Ferodo DS2500 and the A1RM's win hands down!!!!! They even feel better than the Endless and Project Mu pads I have tried in my other cars...
Low dust, great pedal (the best pedal feel by a long way!), and excellent fade resistance with pedal control...
Highly recommended IMHO...
http://www.opelaus.com/forums/showpost.php...mp;postcount=10
:down:
Hi mate,
Easiest way to order is to PM me your details, full name, delivery address (preferably a work or business address!!), contact number and email and I can fire you through an invoice with direct deposit details, or else credit card over the phone is also available, 1300 884 836.
Regards,
Greg
QFM HPX Fitted To VT V8 Holden Calais!
My Calais was simply unstopable, brakes had no feel, no stopping power, it was no good at all. Then I discovered HPX brake pads. My car feels so much better, the car pulls up really quick with no brake noise and they don't fade at all.
THANKS GSL :yeah:
http://forums.justcommodores.com.au/1322224-post106.html
A1RM Fitted To Mazda!
hey just wanna thank you for the qfm a1rm pads. i raced today at oran park and didnt get any brake fade what so ever. on the track for 15minute periods and driving hard they felt great!
No link available, received via Private Message
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
