Item:1994 TOYOTA ARISTO
Item Condition: A1 WILL NOT DISSAPOINT
Price and Payment Conditions:$16,500 RWC OR SWAPS
Extra Info:
IM THE 1ST AUSTRALIAN OWNER
94 3.0V TOYOTA ARISTO
2JZGTE TWIN TURBO AUTO
JET BLACK
GETS AROUND 550KMS TO A TANK WHICH ISNT TO BAD AT ALL
-CUSCO COIL OVERS (NEW)
-FRONT MOUNT INTER COOLER 600X300 (NEW)
-FRONT MOUNT TRANS COOLER(NEW)
-18INCH KARLSON RIMS BLACK BRIDGESTONE 265'S STRETCHED ON REAR
-K&N POD FILTER WITH CUSTOM INTAKE PIPE (NEW)
-FCD (NEW)
-TXS BOOST CONTROLLER SET TO 14PSI (NEW)
-TAS PERFORMANCE 3INCH EXHAUST WITH HIGH FLOW CAT AND MUFFLERS (NEW)
-BLITZ BLOW OFF VALVE (NEW)
-AUTOMETER BOOST GUAGE(NEW)
-7INCH DVD PLAYER TOUCH SCREEN DVD/IPOD/USB/RADIO/MP4/MP3/DIVX (NEW)
-12INCH SUB 1200WATTS WITH AMP (NEW)
-AWESOME SPEAKERS WITH TWEATERS IN THE FRONT PILLARS SOUNDS GREAT UNSURE OFF THE BRAND IN THE CAR WHEN I GOT IT
-ELECTRIC SUNROOF
-ELECTRIC SEATS AND STEERING WHEEL
-AIR PURI
-ELECTRIC WINDOWS
-ABS
-TRACTION CONTROL WITH ON/OFF SWITCH
-STANDARD LSD
-CRUISE CONTROL
-HKS TURBO TIMER
I HAVE SINCE OWNING IT MAINTAINED THIS CAR TO KEEP IT FOR THE LONG RUN BUT DUE TO MOVING CITYS AND LOOSING MY JOB CANT AFFORD TO KEEP IT
SINCE I HAVE HAD THE CAR I HAVE DONE
-GATES TIMING BELT WITH NEW TENSIONER
-CAM AND CRANK SEALS
-NEW WATER PUMP/HYDROLIC FAN PUMP
-NEW GENUINE HARMONIC BALANCER ($500+)
-GENUINE BALL JOINTS FRONT (TOP AND BOTTOM)
-NEW DRIVE BELT SPRING LOADED TENSONER
-NEW POWER STEERING PUMP ($850+)
-A/C REGASED
-SERVICED IT EVERY 5000 KMS WITH FILTER CHANGED EVERY TIME
-100,000KM S WAS DONE ALL OILS AND FILTERS PLUGS ETC CHANGED.....
CAR IS WERE WELL MAINTAINED OVER ALL THE CAR IS STUNNING EXCEPT WHERE MY CAR GOT EGGED OR SOMETHING CHUCKED AT IT BUY @#$!S DRIVING PAST I WAS LUCKY ENOUGH HAD TO CUT POLISH IT WHERE IT WAS HIT AND NEEDS JUST TO BE BUFFED
CAR MADE 220HP AT WHEELS ON STOCK BOOST COMPLETELY STOCK
IT FEELS FAST TO DRIVE IM GUESSING WITH THE MODS NOW IT WOOD BE AROUND THE 270HP@WHEELS MARK
(IF I EVER FIND OUT WHO IT WAS I WILL f**kING BREAK YOUR SKULL WITH A HAMMER)
Contact Details:BROCK 0410490449
Edited by lag13
https://www.sau.com.au/forums/topic/273295-toyota-aristo/
Nice Clean R33 With Big Turbo!-- 400+rwhp
Not sure if that link will work as im new to this.
car is on carsales if you want to see it and the above link does not work. do a search for plates.. -143KBL-
let me know what you think.
thanks.
https://www.sau.com.au/forums/topic/273295-toyota-aristo/#findComment-4646421
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
