plastic welding
32 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • 1 month later...
Hi Jon,
I'm looking at doing a little cut and shut with 2 different front bars of differnet makes. In the past I have glassed them together, but all it takes is sloppy flat bed tow guy to crack them at the join, even with good prep.
Are you able to do this kind of work?
most probably .... as long as they are both compatible material with eachother then its usually all good
cheapest way for you is if you want to cut and shut the bars so they fit together neat and square and ill just weld it all up for you....
what are the two cars the bars are from??
I got most of them out with a real fine grit paper but there are still a few that are a bit deeper that I cbf putting in the time or effort to get out.
Ill see if I get time to take them out and drop them off next week when im home :P
