WTB COIL PACKS FOR RB20/25 (RB20/25 COIL PACKS THAT WORK, NOT SHIT ONES!!!!)
WILL PAY FOR POSTAGE COST (IF YOUR NOT IN BRISBANE)
CHEERS GUYS :)
UPDATE:::
ok i'v been told rb25 coils might not fit or work> true or not true???
i have a rb20 redtop so dont want to spend money on 25 ones if there not going to work
cheers
Afaik, s1 rb25 and rb20 both have seperate ignition (pulse) modules, s2 onwards have them built into each coil.
So if you're still running the original coil-ignition (pulse) module setup I can't see a problem with you running s1 r33 coils.
Edited by madbung
yer all original coil-ignition (pulse) module how much for a set mate?
No problems, these ones do work (all 6)..I'd have though $20 per coil pack plus packaging and postage cheap compared to new nissan items or splitfires ect.
Meh, I'll put em in the forsale section.
i got set of 6 from an rb25 neo...no longer need em as i got splitfires now...
am located on sunny coast...all of them work...make an offer on em and they r urs...
0423366417 if u wanna talk quicker i'm not on here much
yer thanx mate but neo ones wont work i dont think?
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
