Do I need to install an air flow meter with my pod filter on my N/A or just take the air box off and whack on a pod filter? Some people say it doesn't really matter, others I've asked said yes definately put an AFM on, what do you guys reckon and what are you running?
https://www.sau.com.au/forums/topic/273649-pod-filter/
Yes you do.
The AFM (air flow meter) measures how much air flows into the intake, sends that to the ECU which then adds fuel accordingly. Without it the car won't function correctly.
Unbolt the air box, bolt on a pod filter adapter to the AFM (unless you're using an Apexi pod designed to connect to the factory AFM), and then slide on the pod and tighten the strapping.
As you're in Melbourne, I believe the law says that it must be secured and enclosed. So the next step will be to use a bracket to secure the pod to a factory bolt (universal aftermarket item will do, or piece of aluminum with holes drilled in it), and then either fabricate a air box or buy an off-the-shelf one.
A pod without shielding it from engine bay heat, particularly in an N/A will show neglible gain in performance, if anything lower performance. After all that, running a cold air feed into the box will help get the most benefit out of a pod filter.
In short, unless you want the induction sound and looks of a pod, keep the stock air box and run a high flow panel filter.
https://www.sau.com.au/forums/topic/273649-pod-filter/#findComment-4642079
Yes you do.
+1 get an AFM
https://www.sau.com.au/forums/topic/273649-pod-filter/#findComment-4642100
pods arnt necessary . your looking for fine filtration . which can be found in a high flow panel filter. disreguard the pod filter mod and go with the panel filter . will work alot better and not suck in heat and engine grime - G
https://www.sau.com.au/forums/topic/273649-pod-filter/#findComment-4642163
Unless your going to have a heatshield & cold air intake a pod will be useless..Id say go with a K&N air filter..cant go wrong with them.
k&n is shit house
3A ftmfw beter and like 1/4 of the price
theres a few engine management units that alow you to run no afm
https://www.sau.com.au/forums/topic/273649-pod-filter/#findComment-4644385
as said above, u can go very wrong with some K&n stuff.... they are an oil based filter, meaning that the real tiny nitty gritty stuff gets trapped in the filter by the red oil (that gives it its colour). This oil can-not always- cause headaches when trying to tune the car and it is screwing with the afm as the car is sucking in oily air to try to get the right ratio to mix with fuel... this can happen when u clean them and u reapply the oil and u put too much on, or even from just chuking one on from new.....so imo, better to go for a dry pod...
https://www.sau.com.au/forums/topic/273649-pod-filter/#findComment-4644502
MAP Sensor alows you to run no afm
A MAP (Manifold Absolute Pressure) Sensor is a micromechanical sensor that measures the absolute pressure in the intake manifold and compares it with a reference vacuum, not with the ambient pressure. This enables the air mass to be precisely defined.
The measuring element is at the heart of the micromechanical pressure sensor. It is comprised of a silicon chip in which a thin diaphragm has been etched micromechanically. Four deformation resistors are diffused on the diaphragm. Their electrical resistance changes when mechanical force is applied. The measuring element is surrounded on the component side by a cap which, at the same time encloses the reference vacuum. They are extremely robust and insensitive to aggressive media such as oils, fuels, brake fluids, saline fog and industrial climate. The pressure sensor case can also incorporate an integral temperature sensor, whose signals can be evaluated independently. This means that at any point a single sensor case suffices to measure temperature and pressure.
Edited by ONE-VIA
https://www.sau.com.au/forums/topic/273649-pod-filter/#findComment-4648966
all this anti-K&N is stupid. You only have problems if you over oil your filter like a ding dong. I had one for over 2 years and not a problem. Me and many others.
you know, first time I did it, gave it the lightest spray of oil after cleaning it, put it on the car after letting it dry for about an hour, no dripping, no worries... leave it overnight, go check in the morning... All this crappy red oil sitting under it... so i take it off.. clean it again and spray even lighter... same process, no oil the next morn underneath it...thought great! It STILL caused problems with idle/tuning.... took it off and put a drift pod on... no issues... but i know not everyone has these problems and it started after putting the boost up on my car, but when it was n/a there were no problems.
https://www.sau.com.au/forums/topic/273649-pod-filter/#findComment-4649962
Give or take 1% there is actually no difference but if you want to go buy tests the most recent was autosallon and 3A won 1st in performance and 2nd in filtration
k&n got 1st in filtration and 4th in performance and i have an Apexi and it got 6th for both but its a slight difference that i cant even be bothered to change.
https://www.sau.com.au/forums/topic/273649-pod-filter/#findComment-4651806
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
