Hey guys, i've got an R33 thats had a hit on the passenger side door, so it's being parted out. Its a '96 S2 R33 Gts-t with approx 82,000 ks, in silver (KR4). Located in sydney
Engine and Gearbox are sold
Front end (headlights, bonnet etc) sold
Apexi Catback exhaust, pickup only! - $300
Batmbl stainless split dump/front pipe, pickup only! - $200
Catco 3" hi-flow cat. To suit r32/r33, maybe 34? - $100
post-35556-1244447526_thumb.jpg post-35556-1244447504_thumb.jpg post-35556-1244447939_thumb.jpg
Engine parts:
Standard turbo, good condition. Minimal/no shaft play - $250
S2 Rb25det manual ECU - $100
S2 Rb25det engine loom - $200
S2 Rb25det coilpacks - $100
S2 AFM, has one cracked mount - $50 ono
Aircon compressor pump - $100
Power steering pump - $100
Alternator - $80
Stock exhaust manifold - $50
Turbo oil/water lines + banjos - $50
Rb25det injectors + rail + FPR - $120
Rb25 Engine Mounts - $80 pair
S2 throttle body & TPS - $50
AAC valve & gasket - $50
coilpack cover - $50
CAS - $50
o2 sensor - $40
A/c condenser - $150
Aircon thermo fan - $60
Rubber intake pipe - $25
BOV recirc piping - $25
Crossover pipe + Stock BOV - $50
Fuse box lid - $20
Washer bottle - $20
Radiator overflow bottle - $20
Charcoal canister - $30
Stock airbox & snorkel + filter - $100
Stock SMIC piping - $50
Stock sidemount intercooler - $40
Bm-44 non-ABS brake master cylinder - $80
Also have a spare S2 ABS pump - $100
post-35556-1244447957_thumb.jpg post-35556-1244447980_thumb.jpg post-35556-1244448093_thumb.jpg post-35556-1244447851_thumb.jpg post-35556-1244447992_thumb.jpg post-35556-1244449685_thumb.jpg post-35556-1244449909_thumb.jpg
Suspension & brakes etc:
Apexi WS Damper coilovers front & rear - $800
(only fronts pictured but its a full set)
Front calipers - $280
Front rotors - $50
Rear calipers - $160
Rear rotors - $50
Front lower control arms - $70 each
Front upper control arms - $40 each
Front 5 stud hubs - $80 ea
Rear 5 stud hubs - $150/pair
Rear strut brace - $100
Rear GTR swaybar, 27mm - $100 pickup only!
Rear lower control arms - $50 each
Handbrake assembly & cables - $150 pair
Manaual (4.11) diff - $200
Driveshafts - $50 pair
Interior:
GTR Instrument cluster (vspec) ~82,000ks, great condition - $250 ono
Floormats - full set, drivers side front mat has slight damage - $80
S2 Steering wheel with airbag - $250
S2 Gear stick surround - $50
S2 Ashtray - $20
S2 dash pad (with passenger airbag) - $300 pickup only!
Drivers side window switch - $80
Boot interior + carpet - $80 pickup only!
Climate control - $50
post-35556-1244449145_thumb.jpg post-35556-1244448540_thumb.jpg post-35556-1244448608_thumb.jpg post-35556-1244449113_thumb.jpg post-35556-1244449129_thumb.jpg post-35556-1244449162_thumb.jpg
Glovebox - $40
Passenger door motor - $50
Centre console - $50
Drivers seat, has some wear on the side where you get in - $50 pickup only!
Seatbelts - $80 (will seperate)
Ignition barrel & locks + key - $100
PM me or reply here if youre keen on anything!
Cheers
https://www.sau.com.au/forums/topic/273778-wrecking-s2-r33-skyline-gts-t/
  • Replies 64
you have a pm.
Pm replied
pm sent
Pm replied
u dont have a starter motor by any chance do ya
Hiya, yep i do. Pm sent
Gots sideskirts!?
yep still have them, passenger side will need a respray though. pm me if interested
whats the best price you can give me for the steering wheel? between 100 and 150 is a good price.
I have a spare series 1 wheel you can have for $120. pm me if interested
Hey Mate,
Do you have the surround for the steering wheel column...as in the the plastic cover that goes between the cluster and the steering wheel?
If so, how much? also interested in the front/dump pipe....please Pm me your email of mob number
Thanks
David
i wil take the injectors, rail and reg.
pm sent :happy:
PM sent :(
prob gone but front bumper???
Yeah sorry mate it's gone
Hey Mate,
Thanks
David
Sorry mate the column surround is gone, and the dump/front pipe is sold pending payment
have u still got exhaust??
pm me
yep, PM sent
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
