hey everyone.
Finally decided to give it all up and sell up all my bits and pieces that i've been hording for ages now.
Any questions or offers then just ask.
All parts are located in brisbane on the northside.
XHP Speedster Wheels in chrome 5 stud 19 x 8.5" +35 all round look and sit great on my 33 just dont like the bling look. few gutter scratch marks here and there but nothing nasty. have federal 595 tyres fronts 80% rears 70% but camber worn. $1500
rb25det Motor, was built 10 000kms ago with balanced stock internals ACL FORGED pistons 8:5:1 compression (for higher boost) stock head etc. comes with forward facing plenum (greddy copy polished) high mount turbo manifold (xs power) and hypergear tr43 turbo with 0.5front and .58 rear and 3inch dump pipe. $2000 ono
Wolf 3d Version 4 plus with hand controller and rb25det loom. has a very safe tune to suit above mentioned motor. made 190rwkws on 14psi $1250
R32 5 speed box in great condition $300
Series 2 rb25det G/BOX, 101 000kms have been done on this box (have cluster to prove) $1300
Bosch 040 intank fuel pump (genuine) Brand new. $150
R33 gtst front disc rotors and calipers, good cond. come with pads aswell unknow brand. $300
R33 gtst dash from series 2 $100
R33 gtst cluster manual from series 2 (reads 101 500kms) works perfect $80
33 gtst alternator $50
33 gtst starter motor $50
33 gtst Steering rack good nick $100
33 gtst front suspension arms and uprights with stub axles and stock shocks and springs $100
33 brake booster $50
33 steering wheel (airbag still good not deployed) it is the whole steering colomn aswell $150
33 power steering pump and resoviour good cond. $50
Fet type r turbo timer $70
Razo turbo timer $90
R33 Lowered king springs front and rear $50
R33 radiator good condition $100
R33 series 1 coilpacks, removed due to fitting splitfires, worked fine when removed. $80
OBX rising rate fuel pressure reg. $80
Genuine hks boost guage in bar not psi bout 40mm the guage is quite small was fitted were the clock on the dash is in my 33. black face with red numbers. $50
33 smic series 1 $40
All items are pick up only. SORRY
have had too many dramas with postage and just dont have the time to piss around with it.
PICS WILL FOLLOW WITH INTEREST as there is a few things here although will put up picks of the engine and so on shortly.
Located north side of BRISBANE
pls pm or sms 0430 218 339. justin....
https://www.sau.com.au/forums/topic/273815-qld-heaps-of-good-stuff-suit-r33/
hey bro looking at the rims, they pritty sweet but 1500 is a bit steep, may be able to afford for 1000 if it comes with rubber. Also what condition is the steering wheel in, need a new one with a bag so insurance will cover me.
Hit me back asap on prices.
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
