Item: PARTS
Website:
Item Condition: USED BUT GC
Reason for Selling: NOT NEEDED
Price and Payment Conditions: VARIOUS
Extra Info: CAN POST
Pictures: GOOGLE
Contact Details: PM
Nissan S13 Parts:
S13 Brake Booster - $65
Dash cluster manual - $60
Dash cluster surround - $30
steering Column (wheel and column to steering rack) - $120
SR Front seats - $70 pair
Rear view mirror - $30
Ignition barrel with door locks and boot lock with key - $150
Rear REO - $75
Rear Bar GRAY VGC - $80
S13 Tail lights VGC - $100
Stock Suspension front and rear - $200
Full SR20 brakes and calipers - $250
FRONT DOORS complete - $175 each
Front guards VGC - $120 each
Boot lid with holes shaved - $150
Sr20 rear cradle HUB TO HUB - $350 including all arms
S13 NISMO STRUT BRACE WILL CLEAR RB - $85
2.5" press bent back incl cat with oval muffler PERFECT FOR N/A or BUDGET - $150
S13 Manual pedal box - Brake and clutch - $180
Black s13 carpet VGC - $80
Roof lining - $60
Rb20DET PARTS
Intake plenum - $150 INCLUDING Throttle body, and injectors
Fuel rail with x6 injectors - $120
Rb20 Block with crank and sump - $80
RB20 head with cams and cam gears - $100
Crank angle sensor - $100
RB20 Power steering pump - $75
Nissan Stagea RS4 Ser 1 parts:
Window regs RHF LHF - $75 each incl motor
Rb25 AUTO AWD Gear box - $300
Front reo -$75
Bonnet - $300 SONIC SILVER
Front guards $100 each - SONIC SILVER
Front door cards - $45 each
LHR Door complete - $200
RB25 Auto Radiator VC - $150
Passenger Mirror front SONIC SILVER - $75
Strut brace, front adjustable - $80
Black vinyl venetian - $70
Rear tail lamps - $75 each
Tail gate complete with wing - $350
NISMO side skirts - $120
Nismo front bar with lip - $250
Nismo rear bar with lip - $250
Corner lamps, smoked clear - $80 pair
Will add more when i figure out whats left
If you need anything not listed off a Stagea or S13 please PM me
https://www.sau.com.au/forums/topic/273830-s13stagearb2o-parts/
Item: PARTS
Website:
Pictures: GOOGLE
Contact Details: PM
Nissan S13 Parts:
Rear REO - $75
Roof lining - $60
Rb20DET PARTS
Front reo -$75
Do you have any idea of shippingcosts to Sweden?
Interested in some lights, sideskirts even front guards! Depends on shipping.....
Thanks
Any idea how much shipping would be to sydney on the sideskirts and rear lip? (if you would seperate from bar that is)
Man shipping is no issues but ur looking at around $100 for both.. and just for u i will seperate!
Mate shipping is no worries.. but ur looking at $100 ish and for u i will seperate!
Chasing Stagea clock from top of dash?
Any pics of nismo rear bar and need both passenger doors?
gold coast
clock and both doors are gone.
pics of the rear bar you'll have to check the stagea forum as they up on there
  • 5 weeks later...
Are the nismo body parts, side skirts and bar with lip only for a stagea or do they fit a S13 as well??
Could you possibly PM pictures or on thread !!
If they fit a S13 you got it sold !!
Are they plastic or fibre glass ??
Jase.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
