www.racinglab.com/rotawheelsd2.html
Ok I'm about to order a set of these in 18x8 +25 fronts and 18x9 +30 rears according to the offset calc it will sit nicely (unless someone can advise me better) on my r33 gtst
My only problem is I'm not sure why it means when it says 5x114.3 +35mm 73 hub (what is 73 hub?)
Other than that these look damn sexy and will set me back only $1260 delivered and weigh only 10kg each which is decent
https://www.sau.com.au/forums/topic/273884-buying-wheels-from-america/
  • Replies 53
Yup just checked the details of my set it's 18x8 +25mm 73 hub and 18x9 +30 73hub all in 5x114.3 , if someone can tell me what that 73 means it will be awesome! Btw not buying from that site which is more expensive.
Are these available in aus?
you should still request if they can provide hub rings just in case.
bit off topic, have you already got a quote to bring in to aus? I;m in the process of buying a set of swaybars for my car and delivery is going to cost almost as much as the swaybars themselves lol
$400AUD bloody expensive but these look nice and still cheaper than buying decent rims here, unless I bought drifteks which are a decent price, so I'm tossing up between those 2, still waiting on a reply from wheelworx!!
If you are planning on lowering your car to the hieght where the tyres sits under the guard, you will have to throw in a bit of negative cambre to make them fit.
I got 18 x 9 +32 on mine, and I have to have around -1.2 negative camber to ensure the wheels dont rub on the rear guards.
Cheers.
Cheers.
wrong... you do not HAVE to run negative camber at all, just roll your guards a lil.
adding negative camber to make rear wheels fit is just stupid from a performance perspective.... especially when you are looking at 375rwkw. skylines give themselves enough neg camber when you slam them as it is!
i run 18 x 9.5 +30 on the rears with positive camber, and they sit almost flat.
18 x 9 +30 will fit easy... although i'd go a bit wider imho... yours will sit 6mm in from mine.
for reference i run:
235/40/18's and
5/7kg coilovers
positive camber a few deg, but cant remmeber exactly
car is 10mm lower than in that pic now (320mm centre to guard)
i can just 1 finger up to the second knuckle between the guard and tyre
car also has swaybars and strutbraces front and rear
guards are rolled but not flared - paint did not crack
i do not get any scrubbing to worry about, a tiny bit of black on my finger if i run it around the guards, and only if its been driven hard
the 73 hub should be aight.... from memory mine are 76mm and i had custom hub locators made up, but most people that run professors dont bother...
235/40/18's and
5/7kg coilovers
Why would you run 245s on a 9.5 wheel?
Yes, with 245 tyres, it will fit under the guard. Why you would put 245 tyres on a 9.5 inch wheel puzzles me, but ey, whatever tickles your fancy.
I have 265/35/18 tyres on my wheels, hence, the reason why I had to place a bit of neg camber to make them fit under the guard.
i run 235's cause i'm one of those fitment types that you hate >_<
car makes 300rwkw, so with decent 235's and flat camber i get pretty good traction and tyres are cheap as 235 is a very common size and they dont last me long
i run 235's cause i'm one of those fitment types that you hate :P
I had Toyo R1s 235 with -0.5 camber on the rear with my R34 GTT rims, running 256 rwkw. My car was all over the place in 1st and second gear.
I now have 312 rwkw with Khumo 265s KU31s and still decent camber, and it spins even when I engage in 3rd gear.
This may be due to the Jim Berry full monty (carbonic) clutch I have. Nonetheless, even when building boost in second gear, the car spins all over the place.
probably your camber dude... as i said we are running the same power at the moment and i'm not doing tooooo badly...
what diff you running? its a locker yeah? i'm on a 1.5 way nismo (i think left that out of that pm)
on 250rwkw with the same setup i had full traction in everywhere...
shouldn't you be running positive camber in the rear to aid traction as I said before when the car squats you get 0 camber therefore more contact between tyre and road, but I guess it also depends how much positive camber you can run
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
